Old 10-31-2012, 12:18 PM   #1
cheford
Question about control arms
I built a 56 F100 on a 72 C10 chassie and was wondering if it would be possible to shorten the control arms to narrow the track width. I've already purchased the new modular spindles from CPP which has helped some but the tire is still quite close to the fender. Thought I'd ask this question to see if it were possible and if it would throw the geometry way out of wack. I currently have the stock 6 x15" rims but with the modular spindles they seem to rub the lower control arm when turned lock to lock.
cheford is offline   Reply With Quote
Old 10-31-2012, 04:55 PM   #2
69gmcc10
69gmcc10's Avatar
Re: Question about control arms
Here is a thread that discusses this. The last post covers the changes and who to contact for more info.
http://67-72chevytrucks.com/vboard/s...d.php?t=537263
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 10-31-2012, 05:19 PM   #3
Pro Performance
Pro Performance's Avatar
I would recommend the Porterbuilt arms which can be built 1" narrower for your needs. They can be made for an air bag or coil spring application. Let me know if you need a set or need further help, as we are a Porterbuilt dealer.
Travis
Pro Performance is offline   Reply With Quote
Old 10-31-2012, 09:20 PM   #4
cheford
Travis
Thanks, this was the information I was hoping to get, that someone actually makes this provision in control arms. Right now I'm in the process of wiring my truck and assembling it now that I have it painted. I'm in the hopes of getting it road ready for next summer but have had those hopes for the last couple years but this is as close as I've ever been. What would a set of control arms cost to fit the stock crossmember and coil springs and what all is included? Much appreciation for your responses.
Old 11-01-2012, 11:19 AM   #5
Pro Performance
PM Sent....
