Iginition Lock on 67 Suburban
I just acquired a 1967 GMC Suburban that did not come with keys. I have not been able to remove the ignition lock, very frustrating. I have been able to loosen the ring that holds the ignition lock in the dash but after a few turns, it just spins around. Can anybody give me the trick to remove the lock without the key?
![]() Join Date: Jul 2007
Re: Iginition Lock on 67 Suburban
Cut it out with a grinder or sawzall. I dont know of a way to get it out without the key. IF you did have the key you put a paperclip in the tiny hole in the face near where you put the key and turn it back until the lock cylinder comes out.
Others might chime in on a way they have found without the key.
Phil '70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver '72 short super build 4wd '72 Suburban LT4 coming soon!! |
The Older Generation
Welcome to the board John. Read this thread... http://67-72chevytrucks.com/vboard/s...d.php?t=462981 s_nova69, you should read it too, it will give you a better understanding of the procedure so you can pass the correct information on. Let me know if you have any other questions... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-31-2012 at 09:13 PM. |
