Old 10-31-2012, 06:32 PM   #1
blazer2007
AOL leaf spring question
I mocked up my AOL setup leaving 3 leafs and a 1 inch spacer on a flipped rearend on a 78 blazer.Now I put one side together with the dowel pin through the leafs and secured the u- bolts snug and let it down to see how it was sitting again, now the side I put the dowel pin through is sitting higher than the other side.The hangers look to be the same and not hanging up.It sat level when it was just a mock up.So I guess my question is with the dowel pin in the leafs would it act as a stronger spring
blazer2007 is offline   Reply With Quote
Old 11-05-2012, 10:13 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: AOL leaf spring question
I'm not reading what you did with the other side. Is it bolted together or the pack is loose?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-06-2012, 11:25 AM   #3
blazer2007
I got it figured out.The truck sat fine on jack stands in the rear but with tires was lower on one side by 1in. or more.Started over and the lower sides u bolt plate was hand tight and let the spring sag a bit in the middle and thought I would check the floor for level and it was out by 3/4 of a in. on the bad side,TA DA fixed,I guess with the temp changing here the ground had heaved or sagged under the cement,must be a floating slab or something
Old 11-06-2012, 10:32 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Cool! Glad it worked out. Yeah, I know what you mean about the cold. It was all the way down to mid 70's today.brrr!
Articles-
"Refining Sierra"
Old 11-06-2012, 10:54 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
Sorry I had to haha
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-07-2012, 10:54 AM   #6
blazer2007
Originally Posted by INSIDIOUS '86 View Post
Sorry I had to haha
You find me a kit for a 4 link for a blazer and I,ll put it in
Old 11-10-2012, 10:13 PM   #7
INSIDIOUS '86
One would think all the truck 4 link kits would go right on in as well c-10-k-5 are pretty much the same suspension wise
Old 11-11-2012, 03:03 AM   #8
andrewmp6
Its not the suspension its more the rear half of the frame is different.A universal 4 link can work but sounds like a headache to me.
andrewmp6 is offline   Reply With Quote
