Old 10-31-2012, 08:42 PM   #1
mwmeador38
Brown wire with white stripe on ignition switch?
can anyone tell me what the function of this wire is on a 66
with gauges in the dash (if that matters). mine is fried and
currently disconnected but everything on the truck seems to
work so i'm wondering what is the function of that wire? the
wiring diagram shows it going to the generator and forward
lamp harness.
mwmeador38 is offline   Reply With Quote
Old 10-31-2012, 08:56 PM   #2
brokenspoke
brokenspoke's Avatar
Re: Brown wire with white stripe on ignition switch?
Resistor wire?
brokenspoke is offline   Reply With Quote
Old 10-31-2012, 09:47 PM   #3
awbrown
that one is for the alternator ..... or volatge regulator ,depending on what year you have...if you have a one wire alternator then you wont need it ....
awbrown is offline   Reply With Quote
Old 11-01-2012, 11:33 AM   #4
mwmeador38
like i said it's a 66. the original alternator had been replaced
with an internal regulator alternator. the regulator was still
in place and so i replaced the alternator with the correct one.
i have yet to hook it up (the wires) so i guess that brown wire
with the white stripe would be the wire that energizes the
alternator?
Old 11-01-2012, 05:57 PM   #5
awbrown
yes sir....
