1983 silverado, I'm looking for a valve seal how-to/write up
I have heard this is a pretty simple task. Is there a write up about it? I want to see how it all looks and the tools I should use to determine if I feel comfortable with it.
Posted via Mobile Device |
Re: 1983 silverado, I'm looking for a valve seal how-to/write up
bump---
King-918 thank you for the video, the truck in the video is a 2005, is it the same for the 1980 models?
When putting the rocker arms back on what are they torqued to?
#6 | |
Moderator
![]() Join Date: Oct 2008
Chevy smallblock rockers aren't torqued. The rockers are used to set your valve lash. There's a 1/2 page rocker adjustment procedure in the ST-330-73 1973 Chevy Service Manual that I scanned. You'll find it on page 6-51 titled Valve Mechanism.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
I prefer to put the cylinder to TDC for that cylinder and feed in a piece of SPARK PLUG WIRE, that way you don't have to worry about the valve falling down in if the air seal breaks. Might take a bit longer but it's safer
2004 Silverado Crewcab (Dark Spiral Gray) |
BAD BOW-Silverado XST
Welcome to the site Austinite!! I did the adjustment to my original 305. Use this procedure: http://www.73-87.com/7387garage/drivetrain/valvlash.htm
Use umbrella seals. They will reduce oil going down the valve stem seals. |
My 85, I bought the positive seal, they actually clamped around the part of the head that the valve goes through
#10 | |
Just use oil diverters on the rocker arms!! You don't want oil slushing everywhere!! I've done several with the engine running. Follow my video links. I have demo on setting the valve lash to zero my ZZ4 roller cam motor. If you don't want to do it, I know a trusted mechanic that will do it for you.
#12 | |
#13 |
UPDATE: bought used valve covers from the junk yard, cut the top off to adjust the lash with engine running.
replace all valve seals and put rockers back on the passenger side, then started the truck to adjust the lash with engine running, the exhaust is so loud with the valve cover top cut off that I cant hear anything but the noise of the exhaust. I have my fingers crossed that I did it all corectly. any suggestions on what I should try to do? |
#14 |
I think I may know part of problem, I had a hard time getting the valve cover off, so when trying to install the valve cover with cut off top I wanted to remove the part on the manifold (see picture)for extra clearance, I couldnt figure out how to remove it without cutting it off or removing the manifold. I did remove the 2 middle bolts highlighted in the picture. I reinstalled them, I guess this could be part of the problem.
I also removed the othe part you see in the picture, It is still off the engine, so I suppose this could be my problem as well. is there an easy way to get the valve cover on and off easily? it just didnt have the clearence to lift off the engine. |
#15 |
You removed the EGR valve. I think you can remove the cover off with a little trouble. You have really wiggle it to get around stuff and remove it. Those rocker can't be adjusted by noise or ticking. You need a feeler gauge to set the valve lash. The lifters are hydraulic.
#16 |
No No
just kinda a side note on this when you do it you can look at the threads and see how many are exposed on each stud. when you put the rocker back on just get then back to that point again and they will get you very close. as long as you go back through them after you done and running this will save you alot of time.
Posted from 67-72chevytrucks.com App for Android
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
#17 |
What is the procedure for adjusting the lash with the feeler guage?
#18 |
Use the procedure above: http://www.73-87.com/7387garage/drivetrain/valvlash.htm
Another good video to see: A feeler gauge is a final check for clearance. Use the procedures above and you'll be okay. |
#19 |
So can I accurately adjust them as they are right now? Or will I need to rotate the engine to adjust each rocker?
#20 |
can I adjust the lash by tightening the rocker arms until they stops jiggling, then start the truck, let it run, turn it off, retighten the rocker arms that still jiggle and repeat that process until none of the rocker arms jiggle any longer, then add the 1/2 turn to lock them down?
