Old 11-01-2012, 08:38 PM   #1
54belair
54belair's Avatar
Identify a later model front suspension
I finally got the cab hung on the rotissary today and was able to inspect the chassis a little closer. I ended up with two questions today.
Question for this thread is: Is there an easy way (or any way) to identify a later model front suspension (I have a suspicion that when the truck was changed to 5 lug that a newer cross member and front suspension was used.)
Before I start ordering parts for the front suspension--I guess I oughta know what I have !!
Im sure there are some guys who have made this swap-----help please!
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 11-01-2012, 08:52 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Identify a later model front suspension
If you get us pics of what you have then we can help out
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 11-01-2012, 09:03 PM   #3
54belair
54belair's Avatar
I only took one quick shot of it from behind the drivers wheel----
Ill have to get more shots tomorrow from the front-----any particular angle youd like to see?
1968 short stepside
1966 mustang
1966 chevelle ss
My Build Thread
Old 11-01-2012, 09:20 PM   #4
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I can tell you for sure that it is not a 1973 or later. As it would have the larger rubber bushings in the control arms. Maybe it is 1971/72.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 11-01-2012, 09:37 PM   #5
54belair
54belair's Avatar
OK, I like that answer------the p o told me it was a 72 but Ive found so many things that were inaccurate in what I was told. I have looked it over before and believed it to be a 71-72, but today, something just didnt look right (looking for something To Be Wrong I guess) thanks for your observation---
1968 short stepside
1966 mustang
1966 chevelle ss
My Build Thread
Old 11-01-2012, 10:10 PM   #6
midniteblues
midniteblues's Avatar
the crossmember is 67-70 with the the rearmounted drum brake lines.
the 71-72 crossmember had front mounted brake lines for the disc's.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 11-02-2012, 06:37 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That is 100 percent correct. You have a 63-70 main crossmember with 71-72 arms. Sounds like the previous guy who did the work just swapped the arms for ease rather than swapping the whole crossmember. It doesn't matter what crossemember you have other than like midnite pointed out, you have earlier model hard brake lines still in place.
Old 11-02-2012, 09:16 AM   #8
54belair
54belair's Avatar
Well good deal, thanks for the input guys (I knew someone would certainly know).
I initially thought it was 71-72 a arms and spindles (because I was told that) but, like I said lately I was suspicious. Now--off to ECE for some more early christmas presents!!!
All I have to do now is figure out the transmission crossmember issue.
1968 short stepside
1966 mustang
1966 chevelle ss
My Build Thread
