11-01-2012, 11:59 PM | #1 |
Correct Crossmember?
I 've torn my truck down to start a rebuild and it doesn't look like the transmission crossmember is correct for the frame. The truck is an '80 - 1/2 ton - 2wd.
The crossmember is only bolted to the bottom flanges of the frame rails, although there are also four holes in the upright portion of the crossmember for bolts. The frame rail only has two holes in the side for bolting the crossmember, but they line up with the crossmember's upper row of holes. In addition it appears that the crossmember is too wide for the frame as there is a 3/8" gap between the frame and the upright portion of the crossmember. The frame measures 34" wide at the crossmember. Any ideas? Here's a couple of photos. |
11-02-2012, 01:18 AM | #2 |
Re: Correct Crossmember?
Looks fine to me
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
11-02-2012, 07:27 AM | #3 |
yeller
You are missing the loop that goes underneath the right side. As far as the width, the frames tweak a little when supports are moved, bolt up the crossmember and snug it down, it will fit just fine.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
11-02-2012, 12:27 PM | #4 |
Cruzzzn' Vet
Maybe it's time for a trailing arm conv kit was thinking of this when I rebuild mine
http://www.classicperform.com/tech_a...iling_Arms.htm |
11-08-2012, 12:32 AM | #5 |
Thanks for the responses. Now that somebody mentions it, the missing brace on the right side is obvious. Is that brace the same for all '73-87's or are there only certain years that will fit?
11-08-2012, 01:17 AM | #6 |
i have the same cross member. i have had an issue with headers for a camaro in my truck clearing this, so i went over it, and the length of the header force me to conjure up a pipe that went at a solid 70 degrees up right at the member, and then down with a 45 and a 1/4 bend to pull a straight flush exhaust. it was pretty wild, truck enjoyed this a lil side pipe adventure. i wish they made dual exhaust cross members with the dual humps for clearance of exhaust going under the members. the wierd thing is mine had a big braket on the passenger side with a bunch of bolts holding it. looking to swap in an s10 cross member for a manual trans. those got the right clearances. but are these wide enough to bolt on the rails of the frame?
Her name is Quicksilver 1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER gotta pay $$ if you wanna play |
11-08-2012, 10:45 AM | #7 | |
...or you could just have a custom tubular crossmember made.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
11-08-2012, 08:52 PM | #8 |
That would explain why my 74 has to humps on the cross member thanks for the info, if only you could have told that to the po because my drivers side goes under the hump and the passenger side goes over the hump
San Antonio, TEXAS -Frog -I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it. |
11-08-2012, 09:26 PM | #9 |
Yeah, I didn't want to have to have any crazy bends in the exhaust, that's why I picked up the other crossmember. Makes for a nice, clean install.
11-08-2012, 09:29 PM | #10 |
some serious stuff there frog. who done that exhaust?
