![]() Join Date: Feb 2004
1966 fire truck, rear brakes locked up tight
Well, this ol feller is not moving untill I can free up the rear shoes. The adjusting starr (wheel)is froze. I guess I'm going to have to drill and widen the adjusting slot to gain more access in there to get aggressive with it, any other ideas?
Thanks Posted via Mobile Device |
Re: 1966 fire truck, rear brakes locked up tight
Is it keeping you from pulling the drum? Id give the drum a few wacks and see if it'll free. Might also not hurt to pull the bleeder and see if it'll loosen up the pressure. If you can get the drum pulled, you can remove the adjuster from the front.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
![]() Join Date: Jul 2009
Try spraying some Gibbs Brand or PB Blaster through the adjuster slot and see if you can get the star wheel freed up. It might take several applications and some soak time.
sorry.....sent to wrong poster 1st time
#5 | |
![]() Quote:
After messin with em for a few months I freed em up...now the work begins
Thanks y'all Posted via Mobile Device |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
57napco, where ya at in Texas? show us some pictures please!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
