Old 11-02-2012, 09:02 AM   #1
1984SILVERADO
1984SILVERADO's Avatar
Emissions Delete, What is this ???
I am removing my emissions stuff on my 84 K10 with a 78 5.7L 350 motor in it. Can anybody tell me what this part is and do I need it? If not should I just cap off the vacuum ports? It sits back on the manifold in front of the dist.Name:  IMG_0676.jpg
1984SILVERADO is offline   Reply With Quote
Old 11-02-2012, 09:10 AM   #2
bk2life
Re: Emissions Delete, What is this ???
its just a dual port fitting nothign else
bk2life is offline   Reply With Quote
Old 11-02-2012, 09:17 AM   #3
Ski-me
Ski-me's Avatar
Isn't that a coolant temp sensor too?
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 11-02-2012, 10:09 AM   #4
Jonboy
Slots go on anything!
There is a thermal vacuum switch on some trucks, but it usually is in the thermostat housing. If that is behind the carb, it is just a vacuum fitting. One port should have gone to the vacuum modulator on the transmision. If you don't need it, either replace it with a plug or cap them off.
1974 Jimmy- 5.3/4L80e/NP241
Old 11-02-2012, 10:09 AM   #5
86c20
86c20's Avatar
i think some where but i dont think that one is. see no place for pig tails. think chevy did a duel perpose but not sure
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 11-02-2012, 11:40 AM   #6
1984SILVERADO
I have the 700R4 tranny so it doesn't have a modulator. So I should just be able to cap it off. Thanks guys!!!
Old 11-02-2012, 03:21 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Don't just cap it off. Get a 1/4 NPT plug and do it right by removing the whole thing. No sense adding any place where future vacuum leaks could occur if the cap falls off.
Old 11-03-2012, 12:31 AM   #8
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
The top goes to the trans, the other either goes to the vacuum ball for your heating system, or to the cruise control. On mine I have a cross fitting, one for all three.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
