11-02-2012, 01:30 PM | #1 |
14 bolt ff drum size
Hey guys I'm ordering the brakes for my 75 k20 on the 14 bolt ff rear do I need the 11" or the 13" shoes? Anyway to tell without taking the drums off?
11-02-2012, 02:47 PM | #2 |
Chevy Enthusiast
Re: 14 bolt ff drum size
The 13" drums almost touch the inside of the wheels, the 11" you will have a lot of room.
Classicindustries.com was the cheapest I found for the 11" drums, it looks like they are $129.99 each for the 13" for your truck; I don't know what they are anywhere else. edit: Oh never mind it looks like you just need shoes.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
11-02-2012, 03:04 PM | #3 |
Haha that's ok. I think I have the 13" cause they look huge.
11-02-2012, 03:37 PM | #4 |
If your drum looks like this one than you have 13" brakes.
11-06-2012, 08:34 PM | #5 |
I ditched my heavy drums for some discs. shaved off about 80lbs and saved a little money over replacing the drums, hardware, wheel cylinder and shoes.
11-06-2012, 08:44 PM | #6 |
howd you do the disc swap?
78' c20 longbox 350/4-speed-current truck 1976 k20 400/t350 ~sold 1980 k20 350/4-speed ~sold~ missed dearly! |
11-06-2012, 08:47 PM | #7 |
80lbs holy cow
11-07-2012, 08:21 AM | #8 |
11-07-2012, 11:43 AM | #9 |
What are you doing for an ebrake MrHino? That doesn't look like a caliper that is capable.
OP, if you have a full floater, then it should be the larger 13" brakes. I believe it's the semi float that has the smaller 11". |
11-07-2012, 12:07 PM | #10 |
Chevy Enthusiast
No both 11" and 13" came on the full floaters, and they both came on the semi floaters too. It depended on what braking option the truck had.
11-07-2012, 12:08 PM | #11 |
Sorry I think it was more like 50, now that I think about. 80 was what it weighed per side or something like that. I did the swap about a year ago and my memory is slipping with age.
Post 50 of my crusader build thread is where i started the disc swap http://67-72chevytrucks.com/vboard/s...d.php?t=493324 no ebrake, dont use em here in the rust belt. cause more problems than there worth. |
11-07-2012, 01:34 PM | #12 | |
Used to live in the rust belt myself (SW Ohio). What issues are you having? I never had a problem. I've always kept the ebrake cables lubed during regular service intervals. |
