I was wondering if anyone else has had this problem? Seems like my wipers only work about 50% of the time. I have found that if you open the hood and bang on the black box that houses the circuit board, that sometimes makes them go. I presume it's an electrical problem...I'm wondering what I need to replace? The circuit board?
thanks for any ideas |
Re: Windshield Wipers on my 97 work intermitently?
There was a recall on some models but I don't think your truck is covered by the recall.
I have seen other vehicles not covered by the recall that have cracked solder joints on the circuit board. If you are good with a soldering iron, it is an easy fix, otherwise replace the circuit board. [NHTSA Recall No. 03V159/GM Recall No. 03023] Defect: On certain minivans, pickup trucks, and sport utility vehicles with certain model-engine combinations, the windshield wiper motor may fail due to cracked solder joints on the controller circuit board. The windshield wipers could work intermittently or not at all.
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
Hey thanks for the info ChevyTech, appreciate that. I'll get this bug solved.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Happened to me on the I15 just North of St. George Utah in a blizard while I was pulling a trailer Talk abour scary, where all of a sudden when passing a semi that was spraying blinding snow all of a sudden your wipers stop.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " In the end, we only regret the chances we didnt take " " Time is the only currency we spend without knowing the balance, use it wisely ." .. |
Old Skool Club
![]() Join Date: Jun 2001
Greg is right....however, we'd never know they had a problem if we didn't turn 'em on once in a while. Mine always worked when I didn't need them. But, let it rain while in traffic on the interstate....there you go.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#6 | |
Excellent advice, Mark.
1995 5.7 TBI, 4L60-E 2WD LB 3.42 Posi Silverado |
| Bookmarks |
