Old 11-03-2012, 12:19 PM   #1
mknittle
mknittle's Avatar
Por or ?
I am almost ready to paint my frame and am trying to decide what coating to use. Sand blasting is really not an option. The plan is phosphoric acid.followed by Por15, rust bullet or?
I have read a lot of bad things about por15 lately but some people are never happy.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 11-03-2012, 12:47 PM   #2
Iceman_70
Iceman_70's Avatar
Re: Por or ?
I used Rustoleum CombiColor (7300) on my rearend, brackets and other things that attach to the frame. Whenever I get to the frame, I'll be using that as well for it ...
Product Data
Iceman_70 is offline   Reply With Quote
Old 11-03-2012, 01:31 PM   #3
blackdiesel
blackdiesel's Avatar
Re: Por or ?
POR 15 stands for "paint over rust". it will look great for a little while, but it will chalk. It must be top coated "in the window", wait to long and it won't stick.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 11-03-2012, 05:33 PM   #4
53 randy
Re: Por or ?
Check out zero rust, does just as good of job as POR 15, without all the bad toxic stuff. I have used it for years. State and county and city gov. like it because you just clean and paint. The next best thing is epoxy. Check out there web site.
53 randy is offline   Reply With Quote
Old 11-03-2012, 06:49 PM   #5
klutz51
Re: Por or ?
I used eastwood frame paint works good
klutz51 is offline   Reply With Quote
Old 11-03-2012, 07:48 PM   #6
Chris.
Re: Por or ?
POR 15 worked good for me, I used regular POR 15 then satin Chassis coat. I brushed it on and it smoothed out nicely. follow their instructions and use only their products and you will be happy. Also they were helpful and nice when I called before I had decided to order
Chris. is offline   Reply With Quote
Old 11-03-2012, 10:06 PM   #7
Highsider
Highsider's Avatar
Re: Por or ?
I am a novice on body work, but I always trusted Permatex.
This is a thin liquid aerosol. Turns rust to a dark, hard surface.
I am going to spray it inside my doors to slow down the inevitable.
Highsider is offline   Reply With Quote
Old 11-04-2012, 12:35 PM   #8
mknittle
mknittle's Avatar
Re: Por or ?
I have used this with good results. it used to be called EXTEND. it also comrs in a brush on liquid.
Mark
My GMC build.
Old 11-04-2012, 09:10 PM   #9
_Ogre
_Ogre's Avatar
Re: Por or ?
i used por on my frame with no top coat, still black but sees no uv under the body
i also use zero rust, seems equal in use, cheaper to buy
shop air compressor timer
Old 11-04-2012, 09:51 PM   #10
OrrieG
OrrieG's Avatar
Re: Por or ?
I used the POR 15 system on places where I couldn't get all the rust off (not to many). Then epoxy single stage primer and 3 coasts Nason Chassis Black single stage. Dries to a nice finish.
OrrieG is offline   Reply With Quote
Old 11-04-2012, 09:56 PM   #11
rollenhard
rollenhard's Avatar
Re: Por or ?
I used this stuff came out nice http://www.kbs-coatings.com/
Just Cruzin Through Life
rollenhard is offline   Reply With Quote
Old 11-04-2012, 10:18 PM   #12
jimig1
jimig1's Avatar
Re: Por or ?
I used eastwood frame paint and it is pretty tuff stuff
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 11-05-2012, 02:52 PM   #13
Pro Performance
Pro Performance's Avatar
Re: Por or ?
I also used Eastwood frame paint and seems to be very durable considering it is an aerosol spray. It did come out a lot better than I expected, but the prep is very important. I spent a lot of time wire wheeling the frame to get it to bare metal in as many places as possible. The better the surface is prepped for paint, the better the results and durability due to better adhesion.
Pro Performance is offline   Reply With Quote
Old 11-05-2012, 03:00 PM   #14
jimig1
jimig1's Avatar
Re: Por or ?
True, I sand blasted my whole frame. I had to make some ground connection and I had to get a wire wheel on the angle grinder to take some off to make a good ground.
MSRA Member
-George Carlin
Old 11-05-2012, 03:06 PM   #15
arturo7
arturo7's Avatar
Re: Por or ?
Man o man, the more I look into POR, the more confused I get. The website only says to "wire brush loose rust and scale." I can't find a clear definition of scale. Some sources say wire brush down to bare steel, others say POR won't work on bare steel. Can't seem to find any clear reference as to how much rust is acceptable.
Sorry for the hijack, just venting...
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 11-05-2012, 04:38 PM   #16
Chevette
Chevette's Avatar
Re: Por or ?
I always thought that it stood for; When you pay for it, you become........
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 11-05-2012, 05:36 PM   #17
Daner
Daner's Avatar
Re: Por or ?
HAHAHA
I've heard good things about Hammerite paint. I think it costs about the same but you don't need to top coat it like por15.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 11-17-2012, 12:49 PM   #18
zenchal26
zenchal26's Avatar
Re: Por or ?
I used por15 on my frame, firewall, inner fenders. Worked good for me. Sandblasted frame, sanded firewall with 60-80 grit and just knocked off the flakes on inner fenders and sprayed. Everything is holding up well. Stuff is tough I was hitting something in with a hammer and missed thought for sure paint was going to be messed up but couldn't even see hammer mark.
zenchal26 is offline   Reply With Quote
Old 11-17-2012, 03:34 PM   #19
Russell Ashley
Russell Ashley's Avatar
Re: Por or ?
POR 15 is tough paint but at 5X the price of Rustoleum I'm not sure it's worth the extra cost.
Russell Ashley is offline   Reply With Quote
Old 11-17-2012, 07:13 PM   #20
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Por or ?
I've had aquart of this for about a year in my garage (hoping its still good). But I DIDN'T buy the prep stuff. How did you prep? Any in-process photos?
I planned on just wire wheeling down to solid metal and wiping with acetone before painting. Good enough? Has yours stayed glossy like that?
Dan in Pasadena is offline   Reply With Quote
Old 11-19-2012, 11:08 AM   #21
mknittle
mknittle's Avatar
Re: Por or ?
After some research I decided to give rust bullet a shot. It dosen't need a top coat but there is only one color metellic silver. I may not topcoat it depends on how it comes out.
Mark
My GMC build.
Old 11-19-2012, 11:53 AM   #22
bowt1ed
Re: Por or ?
Cost aside - if sandblasting is the choice of prep, would powdercoating not provide a more durable, smooth finish than paint (POR, Eastwood, etc.)? I've got a local connection for the blasting and coating, but don't want to go that direction if it won't provide a better outcome. Thanks, Jim
bowt1ed is offline   Reply With Quote
Old 11-19-2012, 12:33 PM   #23
Dan in Pasadena
Re: Por or ?
Powdercoating is great but not everyone is doing a frame off restoration.
Old 11-19-2012, 12:50 PM   #24
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Por or ?
Powder coating is cool if thats what you want to do. It looks great and is durable. The only reason I don't do it to frames is because I'm known to make changes and its so easy grind paint off make my changes and repaint.
As for me I prefer to get all the rust removed and use epoxy primer and single stage black on my frames. Its durable and easy to touch up. I just don't believe in painting over rust. I'm not saying those products don't work, I just can't bring myself to do it.lol
Kabwe is offline   Reply With Quote
Old 11-19-2012, 01:24 PM   #25
bowt1ed
Re: Por or ?
Thanks BAM!
