Where do I get the Sizes for the box floor boards ?
People say that GMCPaul is wrong. So who is right ? I could use anyu info avaible. I did not have the original boards so there is nothing to copy.
Thanks.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
I have a set of new boards that arent installed yet, what measurements do you need?
The length and width of all the boards. I guess if you could describe the what the lip for the strip to sit in needs to get cut out to would be perfect.
I ordered the Polished Stainless strips from Mar-K
Kinda alot to ask for.
Thanks.
no its not alot
I think it was the board widths ? Not sure though...
It would be really nice if Gee-Emm would be able to get the info.
sheese, hopefully someone can straighten out what was wrong
former desert rat
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
If you bought the strips from Mar-k, then call them and ask. They have an awsome customer service dept. Plus, top notch products.
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const. |
I will get it asap in the next couple days
Thanks.
The overall width of the boards is 6 3/8" with the exception of two of the most inner boards and they measure at 5 3/8"
The lip is 5/8" in from each edge with about 1/8" of material removed. I don't know how these boards will fit because they havent been installed yet. When I took apart the box I measured the old boards and wrote everything down but I don't know where that paper is (10 years ago) ![]() The original boards had a weird shape milled out at each edge unlike the boards I have which have straight cuts As for the lengths, I could get you the length of the longest boards but the rest would be impossible to describe because they curve around the wheel wells |
Thanks I will figure out the other boards.
