Old 11-03-2012, 12:54 PM   #1
75chev4x4
75chev4x4's Avatar
stock springs vs lift spring capacity
Hey guys does anyone know if the lift springs from like tuff country are rated for the same capacity as the stock springs that came on our trucks. This is for a 3/4 ton mine for example is an 8400gvw but I out tuff country 2" springs on the truck? If I was to put a camper on will it have the same capacity as the stock ones did? I was almost wanting to go to the junkyard and get the big 8 leaf pack on the 3/4 tons and put that out back if not.
75chev4x4 is offline   Reply With Quote
Old 11-03-2012, 03:33 PM   #2
Rubble
Re: stock springs vs lift spring capacity
I am not sure what make they are,cause they were on the truck when I bought it.But my 86 has 4" spring lift on rear and yes it's load capacity is less than my 82 that has stock 3/4 ton springs with blocks.The spring lift does ride a bit softer,but it does seem to wander a bit more than the 82 and they are both 3/4.The spring lift is even worse if you hook up the car hauler....
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 11-03-2012, 04:10 PM   #3
75chev4x4
75chev4x4's Avatar
Yea that's what I was afraid of, thanks.
Old 11-03-2012, 04:10 PM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
http://coloradok5.com/springratetable.shtml
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 11-05-2012, 03:56 PM   #5
75chev4x4
75chev4x4's Avatar
Hey guys I'm reading all about the different 52 and 56" springs. My k20 is set il for the 52" in the rear and I'm getting rid of the lift springs and getting a set of stock springs at the junk yard. Would there be any benifit to going to the 56 in springs for my truck moving the hanger back?
Old 11-05-2012, 08:58 PM   #6
75chev4x4
75chev4x4's Avatar
weird, just go home and checked and on my 75 k20 there are no extra bolt holes to move the rear shackle back to use the 56" springs. Unless they only did this on the half tons or not at all on the early trucks I dont see them on mine.
