11-03-2012, 01:48 PM | #1 |
How much does it weigh?
There aren't any commercial scales close to me so I was hoping someone has done this already.
How much does a stock blazer weigh with a 350 in it? And....how much does it weigh with a dana 60, 14 bolt rear and a 350 in it? Just trying to get a close weight so I can get specs for a new cam. Any help would be appreciated Scott
1972 Blazer - Bronco Orange - In the werks http://67-72chevytrucks.com/vboard/s...d.php?t=323444 1991 F250 - Hunting truck w/ Detroit rear locker, ARB front locker, front and rear winches .... and more.... 1997 Grand Cherokee - fun jeep - Detroit rear locker, ARB front locker, front winch, 411 gears, lots of lights ;-) 2004 Hot Rod DuraMax - Dnyo'd at the wheels with 525 HP and 1100 lbs torque.....mustang killer. |
11-03-2012, 02:59 PM | #2 |
Re: How much does it weigh?
I think I tipped the scales at 4600-4800
Posted via Mobile Device |
11-03-2012, 10:55 PM | #3 |
So...with the heavy axles I can figure around 5k then.
About what I figured....thanks for the reply.
11-04-2012, 10:28 AM | #4 |
2WD Jimmy
wow, amazing what a front diff and transfer case weigh. Mine comes in at 4000 (2wd with BB)
11-04-2012, 08:45 PM | #5 |
The 14 bolt he has is 500lbs bare. Weighs more than the small block.
11-05-2012, 01:43 PM | #6 |
11-05-2012, 01:48 PM | #7 |
My 72 4x4 blazer with a 6.0 and 4L60E swapped in, 33" tires on aluminum wheels, AC, PS, PB, single wall top, and with 20 gallons of gas weighed 4,760 lbs.
11-06-2012, 04:24 AM | #8 |
Collector of Projects
ok.. I have the 6.0 but a 4L80e/NP205 combo, D60 and 14bff with 35's. No AC but double wall top... guess I'll be over the 5K mark.... I wonded what the weight of a GMC Denail is (where the motor came from) in comparison...
11-06-2012, 05:16 AM | #9 |
I have a 1991 Suburban that has all the things on your list and it weighs in at about 3 tons empty. I'm thinking you almost have more weight in what you added than what's original. I'd say you are probably close to the weight of a Denali XL. The top on the old Blazers is probably heavier than an equivalent permanent steel top and air con is only a few hundred pounds if original, vintage air probably half that.
So yea I'd say you'd easily be at 5K or so. |
11-06-2012, 11:40 AM | #10 |
Only way to know for sure is to stick it on a scale and see. Most every town has one, scrap yards especially. Slip a guy $20 and he'll let you pull it on there for a minute, that's what I do
