Old 11-03-2012, 03:44 PM   #1
diabloceto
Sending unit fix
I thought I would share this in hopes it might help some people later on down the line fix their sending unit so they can have a gas gauge in their truck.
So a while back I bought a new sending unit for my truck because the old one was toast. I installed it check it, it worked, went in for the night came out the next morning and it didn't work. It's been a while since I have been able to get to investigating it but today I did. Pulled the sending unit then hooked it up and moved the arm and the gauge would not do anything. Hmmm odd. Got to looking at it real hard and started playing with that metal ribbon that goes from the piece that connects to the arm and the where the wire to the gas gauge hooks up at. Bang the guage started working. What? So it seems if that metal ribbon touches any of the metal pipes going down it essentially causes it to read too much resistance and the gauge reads empty. I moved it way away from all the pipes and any other metal pieces and now it works perfectly.
So now my gas gauge is working again and I can stop writing down my mileage and hoping I don't run out of gas going places. I hope this will help someone out there.
Diabloceto
diabloceto is offline   Reply With Quote
Old 11-03-2012, 07:47 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Sending unit fix
Good info man thanks!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
