Old 11-03-2012, 07:12 PM   #1
smoky02
Location: Sunny, Florida, some might call it South Alabama
LSX long tubes with early classic motor mounts
Just like the subject says. I'm trying to find out what long tube headers will fit in my truck and not hang below the frame if I'm using early classic motor mounts?
Thank you in advance,
Brandon
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 11-04-2012, 11:39 AM   #2
smoky02
Re: LSX long tubes with early classic motor mounts
Really no one. TTT
Old 11-05-2012, 09:20 AM   #3
smoky02
Did I ask this question wrong? No one has any idea what long tube headers work well with that conversion?
Old 11-05-2012, 09:22 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Try the LSx forum (it's a sub-forum in engine and drivetrain). Lotsa knowledge there. The Doug Thorley's are a known good fit for that setup...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-05-2012, 11:08 AM   #5
smoky02
I have been looking there. Just thought this would be the right place to ask for our particular year truck.
Old 11-05-2012, 02:23 PM   #6
Number98
Prestige Worldwide
Number98's Avatar
Click here and check out post #412, might help....
http://67-72chevytrucks.com/vboard/s...200387&page=17
Number98 is offline   Reply With Quote
Old 11-05-2012, 02:45 PM   #7
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I used the Doug Thorley 324y-c headers with the ECE mounts. Everything worked well, as they tuck up in the frame. The only issue I encountered was with the ECE transmission crossmember. It was a bit too far back in the frame. I had to elongate the holes in the upper portion of the rubber mount to allow it to slide rearward so the I could install the bolts in the lower portion of the mount. Hope this helps.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 11-05-2012, 05:46 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
I purchased the DOug Thorley headers, also
Frank
piecesparts is offline   Reply With Quote
Old 11-05-2012, 10:25 PM   #9
short-t
short-t's Avatar
I used Doug's headers as well, so far so good!
1968 C10 LS2/4L70e swb fleet side. ECE front disk conversion and 3.5/5 drop. SOLD.
1968 C20 Custom Camper 396 50th survivor! SOLD to northerngmc
short-t is offline   Reply With Quote
Old 11-13-2012, 10:46 AM   #10
smoky02
I will be going with the stainless obx trailblazer SS headers
Old 11-26-2012, 12:06 PM   #11
Hart_Rod
Hart_Rod's Avatar
pictures?
Hart_Rod is offline   Reply With Quote
