Old 11-03-2012, 08:51 PM   #1
forestb
forestb's Avatar
fan clutch
I have heard good and bad about fan clutches. What do you all think.
forestb is offline   Reply With Quote
Old 11-03-2012, 10:37 PM   #2
chevyrestoguy
chevyrestoguy's Avatar
Re: fan clutch
I'm a huge proponent of fan clutches. To me, I'll always run one if I have the room.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 11-04-2012, 06:02 AM   #3
brokenspoke
brokenspoke's Avatar
Re: fan clutch
Your probably going to hear good and bad about them....I use them
brokenspoke is offline   Reply With Quote
Old 11-04-2012, 07:41 AM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: fan clutch
I use them and replace them when I suspect its failing. If you dont use one, Id recommend a flex fan.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 11-04-2012, 08:51 AM   #5
tincan1966
tincan1966's Avatar
Re: fan clutch
My thinking is that if they didn't work the OEM wouldn't use them. If I don't have the room, I use electric- never been to keen on the tin and plastic flex fans. JMO
tincan1966 is offline   Reply With Quote
Old 11-04-2012, 09:24 AM   #6
bama63
bama63's Avatar
Thumbs up Re: fan clutch
x2
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 11-04-2012, 10:15 AM   #7
DoubleL
DoubleL's Avatar
Re: fan clutch
Not meaning to hijack the thread but will one fit on my 292?
My 1965 C-20 project
https://67-72chevytrucks.com/vboard/...d.php?t=835095
DoubleL is offline   Reply With Quote
Old 11-04-2012, 10:57 AM   #8
1972RedNeck
1972RedNeck's Avatar
Re: fan clutch
Did somebody say flex fan?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 11-04-2012, 11:31 AM   #9
DoubleL
DoubleL's Avatar
Re: fan clutch
Yeah....that goes off my possibilities list....
Attachment 1007613
Attachment 1007614
Old 11-04-2012, 05:41 PM   #10
brokenspoke
Re: fan clutch
NEVER EVER use a flex fan...
Old 11-04-2012, 09:03 PM   #11
kcsa75
kcsa75's Avatar
Re: fan clutch
How do you know (suspect) if it's failing?
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 11-04-2012, 09:45 PM   #12
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: fan clutch
For us that are in the dark about clutch fans, what year and model car/truck can i use in my truck? I'm running a 350 that currently has a po installed flex fan. It don't overheat but i want to get rid of that annoyingnwind tunnel noise that said flex fan makes. Thanx in advance.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 11-04-2012, 11:54 PM   #13
Brad54
Brad54's Avatar
Re: fan clutch
If you can grab the fan while the engine is running, and hold it from spinning, the fan clutch is toast.
If you grab the fan while the engine is running, and it cuts your fingers off, the fan clutch is still good.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 11-05-2012, 12:05 AM   #14
nachodog2
Hell yeah!!!
nachodog2's Avatar
Re: fan clutch
-Brad
^^^^hahahahahaaa!!!^^^^
Old 06-11-2017, 04:42 PM   #15
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: fan clutch
-Brad
Just went out and checked mine. It's good.
btw... I'm typing this with one hand.
66 C20 Service Truck:
Old 06-12-2017, 01:21 PM   #16
urmyboyblue
Re: fan clutch
Go with an electric fan. Watch this:
https://www.youtube.com/watch?v=ZXdLgaFXZzs
urmyboyblue is offline   Reply With Quote
Old 06-12-2017, 02:42 PM   #17
MikeN
MikeN's Avatar
Re: fan clutch
I use the clutch and fan from a 69 Chevelle with 350 and A/C on my 64 C10 with a 350 engine.
As it turns out, I own a 69 Chevelle, and the stock clutch and fan cool it nicely. I test fit the assembly onto my 64 C10, and it worked perfectly, so I bought another identical assembly to use on the truck.
MikeN is offline   Reply With Quote
Old 06-12-2017, 05:57 PM   #18
damnyankee36
damnyankee36's Avatar
Re: fan clutch
The only minor thing I don't like about clutch fans is that they are engaged when you first start a cold engine which makes them noisy when they don't have to be. After a minute or so, the centrifugal forces disengage until it re-engages when the temps warrant more cooling.
Other than that, they pull huge amounts of air when needed.
damnyankee36 is offline   Reply With Quote
Old 06-13-2017, 09:27 PM   #19
stsalvage
Scrapper 1
stsalvage's Avatar
Re: fan clutch
I was over at a friend of mines house he had a 1971 nova with a 427 4 speed just had it finished it had a mirror glossy black paint job on it over 4000 back in 1979.I was not there when it happened.he was revving up the motor one last time not more then 3 mins before it happen he was adjusting the carb and hitting the throttle with hard throws.He shut the hood sat in the bucket seat.
We all do it. just one last time.that flex fan made him cry.Its like a middle finger.he had a 7 blade metal one on there but he wanted that 2 more HP.When i saw it I asked him was it worth the extra 2 hp I was 8 years old smart mouth.
He was a very good friend of the family .He put me on his lap and hugged me really tight.
at the time I just thought he needed something to hold.Really tight
All he said was This is how your car talk's to you.Then he got up went in side to get a beer and chips
stsalvage is offline   Reply With Quote
Old 06-14-2017, 01:21 AM   #20
'63GENIII
'63GENIII's Avatar
Re: fan clutch
-Brad
That's messed up Brad. I seriously read the whole thing in amazement before I got it.
Yep. They do talk a little when cold and when really warm start sounding like a B52 BUT, Ive never even worried about the 21" that I have on the Big Block. Wouldn't event think about using an electric primary fan on this truck.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
