06-01-2003, 07:41 PM | #1 |
yeller
67-87 BBC Hooker Super Comp headers 2WD
Hooker Super Comp headers #2826, will fit all 67-87 2WD pickups, Blazers, and Suburbans equipped with a big block.
These are in great shape with only a few minor dings here and there and have been painted black by the PO. I have only run Hooker headers in all my trucks and have never had any leakage or any problems whatsoever, they are well made and have a great ruputation. Thanks - Jeff Last edited by bigblock73; 06-22-2003 at 09:34 PM. |
06-03-2003, 02:21 PM | #2 |
So now whatcha gonna use for headers Jeff?
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
06-03-2003, 02:56 PM | #3 |
yeller
I upgraded to 2" tubes...otherwise same header and mfr.
...Jeff |
06-10-2003, 09:12 PM | #4 |
yeller
EDIT: deleted 1st auction link
06-22-2003, 09:33 PM | #5 |
yeller
1st auction didn't meet the reserve..here is the new re-list with lower reserve
http://cgi.ebay.com/ebaymotors/ws/eB...ory=33631&rd=1 ...Jeff |
06-23-2003, 12:21 AM | #6 |
I like the Comps better than the Super Comps for two reasons;
They are made of thicker tubing (last longer) and are MUCH cheaper. I have been running them for 5 years now and no leaks so far. |
06-23-2003, 12:11 PM | #7 |
Mike.......are you running the Hooker comps for Chevelle #2455 ?
Do you like em'? How's the fit?
06-23-2003, 12:31 PM | #8 | |
yeller
Here is a c/p from Hookers site... Hooker Super Competition Headers are the best header available and always will be... but if Hooker Competition Headers fit your needs, it's the world's best buy! Once Hooker Headers removed just a few of the constraints normally put on their designers when they design a Super Competition header they are able to build a Competition header for a lot less. When the objective became to make the world's second best header they found the cost could be cut in half. The Hooker Competition header is almost as good as a Super Competition at a very good price. Competition headers were designed for the value conscious buyer with the stock to mildly modified engine. Hooker Competition Headers are made from durable 16-gauge material; it welds easier and will last longer under certain extreme climatic conditions, Competition headers are finished with a heat cured, high heat resistant black paint, or optionally with Hookers Metallic Ceramic Thermal Barrier Coating. http://www.racenet.net/exh/hok-comp.php Thanks for hijacking my 4-sale post with your opinion. ...Jeff |
06-23-2003, 01:12 PM | #9 |
I saw your headers on Ebay and they are in Exc cond. Should sell quickly.......
06-23-2003, 01:14 PM | #10 | |
yeller
...Jeff |
06-24-2003, 07:34 AM | #11 | |
Nope.......my headers are listed by Hooker to fit my 1984 2-wd .
They fit good but you are going to have to get around that trans crossmember on the driver's side. I went over mine for more road clearance. Mike Quote:
06-24-2003, 07:41 AM | #12 | |
Jeff,
I will concede that if it is the maximum amount power you are after.....then go with Supers. Hooker makes them out of thinner metal so they weigh less. Less weight/more power and so on. This is kinda like saying one Rolls Royce is better than the other. BTW........Whats up with you and a Reserve? You make more money without one. Quote:
06-24-2003, 07:50 AM | #13 | |
yeller
Also, the SC I have, the tube size I wanted was not available in the comp...not only are the SC lighter, but they have bigger dia tubes for better flow/performance. *Jeff |
06-25-2003, 03:32 AM | #14 |
Jeff,
It may just be me but I don't even bid on things with reserves as I feel it is not a true auction. I guess I just get lucky as I just sold a cam kit with no reserve for $27 OVER retail! This is about the 10th time that has happened too. Oh yeah.....I agree that SC's are "better-tuned" for lack of a better word. Seems Hooker puts more time into their design. Good luck on your auction, Mike |
07-08-2003, 08:26 AM | #15 |
yeller
SOLD! Got more than what my reserve was and also got exactly what i paid for them when I purchased them.
Thanks for the help and tips guys. ...Jeff |
07-08-2003, 12:01 PM | #16 |
finally..........where's my cut
