Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-03-2012, 09:24 PM   #1
72_ChevyMan
72 Chevy Engine questions
What size of cam can I put in my 350 without installing a stall converter. I've been told that if I install too much of a cam it'll take away from my power brakes
72_ChevyMan is offline   Reply With Quote
Old 11-04-2012, 11:25 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: 72 Chevy Engine questions
Way more questions than answers here.,,, A cam is more about a host of other things than brakes and convertor.
Off the hip, and knowing the lame compression that came about in the early 70's... Fair guess is a 268H (its 218° @ 0.050 and only .46 lift),,, it's about all your stock configuration will support, and supply vacuum for the brakes,,,,, and will work with stock rockers, valve springs, piston clearance, exhaust, intake, convertor, gears, most emissions.... etc.
But that's just one suggestion
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
