K&N air filter part number?
I have a 69 350 V8, with an Edelbrock housing and filter like this :
![]() I would like to put a K&N filter in the same housing, so I went on the k&n web site, and typed in my vehicle, and bought the one it says to use. Well, I got it, and it is way too small. It is probably only an OD of about 10". I need an outer dimension of 13 3/4, which I assume is 13.75. I can't seem to just find a round K&N filter that is that outer dimension. Edit. I jus noticed the Edelbrock box says the filter is 14", which is strange because I measured it with a tape. Anyway, I guess I need a 14" K&N ? Do you guys know which part number k&n would fit? Posted via Mobile Device |
![]() Join Date: Jan 2001
Re: K&N air filter part number?
I found this K&N search, but it doesn't return any results for me. Maybe you'll have better luck:
http://store.knfilters.com/mobile/mU....aspx?ID=S0001 Another alternative would be to take your tape measure to your local parts store and find a filter with the correct diameter, then cross-reference to K&N. |
![]() Join Date: Jul 2010
E-1650 is 14x3..i got this on mind with that air cleaner
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
Thanks guys! I just ordered the part number you gave on Amazon
