06-01-2003, 08:03 PM | #1 |
97' Tahoe 2dr/2wd
electric cooling fan ??'s
thinking of using an electric cooling fan on my 70' when i'm going back together.
what is everyone using??? i will be running a 350 and probally a 3 core radiator. yes, cost is a factor....... just wanted to know what works for everyone else, what size fans everyone is using and if there is a certain cfm that i need to look for.. thanks tommie |
06-02-2003, 10:25 AM | #2 |
Obviously, the higher CFM the better. Some numbers that I've seen are like 70% core coverage for a fan without a shroud, which with the rectangular shape of ours you would be better off running two.
I know Classic Heartbeat sells a setup that might be what you are looking for. http://www.classicheartbeat.com/cata...assemblies.htm The question I'd have is what's wrong with the mechanical fan and a shroud? I realize it free's up horsepower, but it also puts demand on your electrical system. I like electric fans, so don't get me wrong, I went through the same thing as you when I dropped my engine in, mainly because of space with my serpentine setup. Found out that a big block shroud would work with the stock fan. A few dollars latter and I'm running the stock fan from the '98.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
06-02-2003, 11:04 AM | #3 |
I too have returned to the stock fan after trying electrics on my 68. I only have an aftermarket cooler on the trans and am concerned about tranny temp. If the cooler was in the rad then it is probably ok. I had the electrics running from a thermostat so they did not run all the time. Tranny temp seemed to be very hot. I dont want to ruin the 700r4.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
