Old 11-04-2012, 02:17 AM   #1
Rob68c10
Convert from powerglide to 700r4 or t56
Hey guys as of right now I have a 307/powerglide in my 68. It's getting close to that time where I start thinking about drivetrain. My goal for this truck is a nice cruiser. Doesn't have to be a power house. I want something I can drive on longer trips and not break the bank. I have been thinking about doing a very mild build on a 327 I have, or just hopping the 307 up a little bit. However the power glide has to go. I just can't decide between a 700r4 or a t56. Is there a huge cost difference in one swap or the other? This is one part of the build of this truck where I honestly have no major preference of which selection to make and the cheapest reliable option will probably beat out the other. So convince me.
Rob68c10 is offline   Reply With Quote
Old 11-04-2012, 05:31 AM   #2
SS Tim
SS Tim's Avatar
Re: Convert from powerglide to 700r4 or t56
Since your truck is already an automatic I would go with a 700R4 or 200R4. Should be a nice easy swap. Just need to get a quality reliable trans. not a CL or junkyard refugee. If it does not have a warranty it is a core! Might need a ratio change if you have tall tires and a 3.73 though.
SS Tim is offline   Reply With Quote
Old 11-04-2012, 09:51 AM   #3
Rob68c10
Not sure what ratio is in the rear I have going in the truck but I plan on running 295/40/20's in the rear and a 255/40/20 in front.
Old 11-04-2012, 10:08 AM   #4
GMCJOE
GMCJOE's Avatar
T56 would be nice if you are going for a performance application. There is a lot more involved in the swap. I doubt with the 307 that you would be pushing enough power to get the full potential of the T56.
I agree with Tim, you probably got something like 3:08's or so in the rear end, and 3.73 would be a great change with either.
If you are going to drop a nice built motor into the truck, you have the option of the T56. It would go great behind a LS swap, or an engine running about 300hp. Ultimately, the 700r4 or 200r4 is going to be the easier swap and fit your application the way it's with a gear ratio change in the rear end possibly.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 11-04-2012, 10:16 AM   #5
Rob68c10
Thanks for the info. I do not plan on running an lsx at this point in time. I want to kind of keep this thing simple (yeah right). 300~ horsepower is about the limit of what I want. Enough to kick the tires and set me back in the seat. What ratio would you recommend running?
Old 11-04-2012, 10:21 AM   #6
GMCJOE
GMCJOE's Avatar
3.73 is a great ratio to be running, and that is my suggestion. I have a 4:11's in my rear axle, it came to me that way and I believe they are factory. I will be running a 700r4 with my setup. Can't afford that T56 transmission, they don't sell cheap!
Joseph
Joe's 69 GMC
Old 11-04-2012, 10:31 AM   #7
GMCJOE
GMCJOE's Avatar
There is a thread on here that breaks down the axle codes if you want to check it to see what ratio you have currently. But that may not be what is in the axle, so it better to pull the cover and see what you got or do one of the other methods of checking. I believe SSTim is well versed in the axle codes.
Joseph
Joe's 69 GMC
Old 11-04-2012, 11:07 AM   #8
Critter
Future TOTM Winner
Critter's Avatar
In my opinion if you are not going to be making gobs of power (350hp+) then don't waste the money on a t56. A nice world class t5 can handle the amount of power you are talking about for a daily driver/cruiser no problem. Some people give them a bad wrap because they can't handle a lot of power especially when they are abused, taken to the track a bunch, etc. If you decide against a manual trans then a 700r4 will be the most readily available.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 11-04-2012, 03:36 PM   #9
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I've done both a 700R4 (67 Chevelle) and currently have a T56 in my 63 Chevy II.
I had 3.08s with my 700R4 and a stockish 350 and that car was a great daily driver as the deeper first gear of the 700 helped with the shallow rear. I currently run 4.56s with the .50 6th gear t56 in my 63 and enjoy that as well, regularly cruising at 75-85 with my hopped up 250. It all comes down to if you want a third pedal or not.
Cheapest way for a t56 is 93-97 FBodies but you would need a conversion flywheel to go to a pre 85 motor (about $400) as well as a way to hook up a hydraulic clutch (pretty simple with a welder).
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
