11-04-2012, 03:05 AM | #1 |
Oil blowing out of the dip stick
Tried the search and could have sworn I have seen the posts before but couldn't find anything.
The 82' I'm having a problem with oil blowing out of the dip stick tube. It only happens when you drive it . Posted via Mobile Device
2004 Silverado Crewcab (Dark Spiral Gray) |
11-04-2012, 04:24 AM | #2 |
Re: Oil blowing out of the dip stick
sounds to me like you have alot of crankcase pressure, it could be a bunch of things but i would start with new PCV valves, if that doesnt remidy your situation it could possibly be bad pistons rings causing blow by
11-04-2012, 08:07 AM | #3 |
Watch out for your cornhole !
With the engine running at idle speed, pull the pcv valve out of the the valve cover and stick your finger over the hole on the bottom of it. You should feel vacuum sucking your finger and hear the little check ball rattle within the valve if you shake it.
11-04-2012, 08:25 AM | #4 |
Well see I knew that, but the PCV valve shakes and I feel vacuum. The PCV is old, so I'm gonna change it, just kept forgetting it and when this guy drove it the other day and brought it back he said something about it. I'm gonna go ahead and change it. Also there is a breather tube on the other side that goes to the bottom of the air breather.
As far as the pistons being bad causing blow by, it doesn't smoke only a puff when you first take off, probably bad valve seals Posted via Mobile Device
11-04-2012, 11:40 AM | #5 |
Just here to tinker
Bad valve seals usually won't build up crankcase pressure like that. I would do a compression check after you replace the pcv.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
11-04-2012, 12:39 PM | #6 |
I know the bad seals won't do it, I was just referring to the smoke on start up
11-04-2012, 01:44 PM | #7 |
When mine was blowing oil out of places it shouldn't the cat converter was starting to clog.
Alex. |
11-04-2012, 04:42 PM | #8 |
No CAT on this, it's a stripped down bare bones 82
11-04-2012, 04:49 PM | #9 |
if it been setting for a long time the rings may be sticking i had the same problem i started driving it and it quit after 3 or 4 weeks
