center caps
has anyone been able 2 run the flat center caps with rally wheels on a 66 c-10 6 lug ---- on the front ---- will they fit over the hub ? Thx
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: center caps
What are these 'flat center caps' you speak of?
...and which rally wheels are you referring to: the 4wd truck rally's or the 'vette type rally's (that now are made in 6-lugs, 5-on-4 3/4-inch circle, and 5-on-5-inch circle)?
Re: center caps
Yes you can use them.
66 shorty ![]() |
Re: center caps
I had to make 100% sure you can use them so I went out and put one on my truck. It's the same as your truck so here you go. And John here is what the flat caps look like. BTW did you see that turkey outside your shop? The thing is huge! lol
66 shorty ![]() |
Re: center caps
The 6 lug Rally's have been made for a long time. I have the receipt for the ones on my truck from Les Schwab from 1999. The guy paid $91 per wheel back then. Not too bad. They are up to $121 now.
66 shorty ![]() |
60-66 Nut
Re: center caps
I wasn't sure if the OP was talking about the OEM 6 hole Rally wheels or the aftermarket ones.
Yeah that Turkey has been around since Spring. Guys in the neighborhood keep feeding her. I don't really mind axcept for all the Turkey poop ![]() Did you get that heater installed yet?
Re: center caps
Im putting it on in the morning. Got all the screws I need and ready to go.
66 shorty ![]() |
