Old 11-04-2012, 11:34 AM   #1
chevyboy73
chevyboy73's Avatar
Dome Lights
What do you guys (with 47-55 first) do with dome lights? Is there a way to make it like a newer car so it turns on when you open the door? Or keep the switch light? Thanks for help!
2011 Silverado ECSB LT
2000 Silverado RCSB 2WD
super bad habit of not owning a vehicle for a long time
chevyboy73 is offline   Reply With Quote
Old 11-04-2012, 01:27 PM   #2
Daze57
Daze57's Avatar
Re: Dome Lights
Wiring Dome Light via Door Switches
this site is by-'' alan horvath.com'' - explains how you can do it - go through his site - he has great things in it for his 54 - including what you are looking for.
good luck
Daze57 is offline   Reply With Quote
Old 11-04-2012, 03:02 PM   #3
parkwood
parkwood's Avatar
Re: Dome Lights
Here is two different ways that i've done it.. the first is on a '51 and the 2nd is on a '55..
parkwood is offline   Reply With Quote
Old 11-04-2012, 04:28 PM   #4
chevyboy73
chevyboy73's Avatar
Re: Dome Lights
Thanks the 55 door thing looks easy to do
Old 11-04-2012, 05:07 PM   #5
OKGMC4
OKGMC4's Avatar
Re: Dome Lights
The second switch is how I did it. If you look for late model GM switches they are self tapping, with the right size hole drilled. (I used 94 astro van switches and practiced on scrap metal to get the hole size right first.)
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 11-04-2012, 06:04 PM   #6
mr48chev
mr48chev's Avatar
Re: Dome Lights
On the AD trucks the light is normally turned on by the swich on the light. The housing is grounded to the cab which doesn't allow grounding door switches to work unless a guy isolated the body of the light from the truck cab and then grounded it with a wire from the light's housing to the grounding switch on the door. That wouldn't be hard to do by drilling out the three holes for the screws that hold it to the cab and putting gromets in the holes to isolate the body from the cab and you might have to do something to keep the cover from grounding to the cab. Then you could run wires from the body of the light to the switchs to ground the light to turn on.
The other thing would be to run door switches that control the power to the light and splice wires into the power feed so that it turned the power to the light on and off and then leave the switch on the light turned on except when you wanted to leave the doors open for a period of time.
A second way might be to run door switches that have a hot in hot when on in the jambs and have a toggle switch under the dash on the feed to the door switches to turn the power off when you want to leave the doors open or don't want the light to come on when you open the doors. The lead from the swith (s) could run to the bulb side of the switch on the light and with the old wire still intact and inplace you could still turn the light on without opening the door.
mr48chev is online now   Reply With Quote
Old 11-04-2012, 08:40 PM   #7
OKGMC4
OKGMC4's Avatar
Re: Dome Lights
Didn't know that about 1st series lights. If one were so inclined it would be a great chance to upgrade to an LED panel. It makes SUCH a difference, mine lights up like the sun at night. Youngrodder did it on his first series here...
http://67-72chevytrucks.com/vboard/s...d.php?t=508867
Hope that helps as well.
Old 11-04-2012, 10:24 PM   #8
youngrodder
youngrodder's Avatar
Re: Dome Lights
You beat me to it...Thanks for digging up the old thread.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 11-05-2012, 01:41 AM   #9
Daze57
Daze57's Avatar
Re: Dome Lights
yep ! i too used youngrodders L E D idea via OKGMC4 - works great !
Old 11-25-2012, 11:59 PM   #10
mobileortho
mobileortho's Avatar
Re: Dome Lights
Got finished mine. Man, this thing is bright!!
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
