Old 11-04-2012, 12:08 PM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Truck out of commission.
Decided to wash and drive my truck today. I had not moved it in almost a week. Pump the gas for an easy start. The pedal went to the floor and didn't return. Check the carb connection. All okay. Go back into the cab and pull the pedal back. Grab the back of it and cable is broken. Stock pedal cable finally broke. Does anyone know the cable length?
25.5" or 25.375"
Has anyone installed a stainless steel braided Spectra cable? With an Edelbrock carb?
Wonder if now would be good time to slap on the 1407 and ditch the 1406? ZZ4 would go from 600 CFM to 750 CFM
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 11-04-2012, 12:11 PM   #2
Redcap
Re: Truck out of commission.
25.5" or 25.375"
1407 is too much carb for that motor.
Redcap is offline   Reply With Quote
Old 11-04-2012, 02:40 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
He's prob right usually the bigger you go in edelbrock the crappier they run
I'm just joking. Throw it on there and tell us how she does eddies have air door secondary's that pretty much makes them variable cfm carbs which is good for the street
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-04-2012, 06:22 PM   #4
Pyrotechnic
Pyrotechnic's Avatar
A couple of years back this happened to me as I was starting up my truck to go to work.
Called up Henna Chevrolet and they were able to get me a new throttle cable assembly pretty quick, though I'm sure Capitol Chevrolet is a bit closer to you. I've had good luck with their parts dept as well.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 11-04-2012, 07:19 PM   #5
SSC's76
No No
SSC's76's Avatar
never used that throttle cable honestly don't know the size I had to replace mine a few years ago local chain parts store had on in stock 14 bucks stock replacement. as far as the carb size depends if you want to do some tunning. I ran a 770 for a while on a 350 took a while to get it right ended up going back to a 600 but that 770 did run better wide open
Posted from 67-72chevytrucks.com App for Android
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 11-05-2012, 08:52 AM   #6
gchemist
gchemist's Avatar
GM specs call for a 750 CFM carb. I've driven a 355 HP dynoed Firebird car. I know what 355 HP feels like. The ZZ4 feels under powered. Articles have been written on them too. I think it still has hidden power. I''ll purchase the new cable tomorrow. I'm taking it off this afternoon. I will install it on Wed/Thur. I'll pull out the 750 and look it over. It's in a sealed plastic bag. It came off a 350 with a performance cam '77 Vette. The Vette had trouble using it. I think engine bay temps were a problem. The Vetter owner removed the carb and sold it to me for $75! Almost brand new too!!
