11-04-2012, 03:24 PM | #1 |
Help identifying what else I need for AC
Hey guys, when I purchased my Blazer the dealer told me the only thing I'd need to get the AC working was a compressor..the PO apparently removed it for some reason. I've consulted my shop manual and from looking at the pictures of the complete Four Seasons AC system it does appear the the compressor is all I'm missing. I'm hoping this is the case and that all the intact parts are in good working order!
Thanks in advance! |
11-04-2012, 03:26 PM | #2 |
Re: Help identifying what else I need for AC
couple more..
11-04-2012, 03:28 PM | #3 |
dont see the front lines to the compressor, should replace the drier, and don't see the condenser either
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott 1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064 1930 Tudor Sedan |
11-04-2012, 03:37 PM | #4 |
11-04-2012, 08:28 PM | #5 |
Here is a picture showing the lines needed. The drier is mounted on the outside of the radiator support on the passenger's side.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
11-04-2012, 08:38 PM | #6 |
Old member
Don't see the vacume valve for the hot water line either. If the system has been open for any amount of time pull a very long and strong vacume on the system when it's all back together.
Cheap insurance is buy a new drier and I would think real hard on swapping it out for a 134-A system condensor and be a lot happier with it in the long run. The cost will be about the same either way. If anyone says R-12 is better than 134-A they don't have a clue as to how to set the system up to work properly. + the cost is a lot less and you can do it yourself.
