2 1/2 exhaust
im looking for pics of 2 1/2" & 3" exhaust systems with a 4"- 6 " drop going out the back...any issues? i think in front of wheels will be to load..
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604) |
Re: 2 1/2 exhaust
I have a 4.5 -6 drop long tube headers and 2.5 exhaust that only goes to 21/4 where it bends out in front of my rear tires. I cut 4 inch holes in my carrier crossmember though. Worked well for me.
![]() Posted via Mobile Device
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. " |
Old member
I have stock ram horns with regular mufflers and I have the ends cutoff righ as they turn down over the rear end because of the track bar.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: 2 1/2 exhaust
Mine 4/6
![]() ![]() ![]() ![]() Posted via Mobile Device |
Re: 2 1/2 exhaust
Couple more I also have a h pipe installed behind the tail shaft housing but no picture at
This time. ![]() ![]() Posted via Mobile Device |
