11-04-2012, 04:58 PM | #1 |
Power Steering Pump
Power steering pump kit with mounting bracket, chrome pulley and high pressure howe included. Asking $100 o.bo.
Thanks, Mike |
11-21-2012, 05:24 PM | #2 |
Re: Power Steering Pump
Bump
01-29-2013, 10:08 PM | #3 |
What year is this pump? Metric or standard threads? What is your best price?
01-30-2013, 03:34 PM | #4 |
It came in a power steering conversion kit from REZ Engineering that is specific for '60-'66 trucks. We used the frame mounting bracket to mount the power steering gear box, but didn't need the pump because a March kit was used on the engine. It's for a V-8, I believe standard thread, but I can double check. $100 shipped would be the best price.
02-05-2013, 03:33 PM | #5 |
Did you check to see if the hoses were metric? What is the best price? Send me a private email if you like.
02-05-2013, 05:35 PM | #6 |
Hose size is standard, $100 shipped (free shipping) is the best price. Thank you
02-07-2013, 03:33 PM | #7 |
Do you know if the pump pulley is set up for a short water pump arrangement? Could you also post a back picture showing what the mounting bracket looks like? Thanks,
02-09-2013, 08:16 PM | #8 |
I believe it is for a short pump, as it came in a power steering conversion kit specifically for '60-'66 C10's. Here are some various pics for you to look over.
Thanks, Mike |
02-10-2013, 01:19 AM | #9 |
60-66 Nut
That is one of the brackets used in the '68-'72's with a small block, which all had the short water pump.
02-10-2013, 10:39 AM | #10 | |
I may have an extra frame bracket to mount the box, If any one is interested, I will throw that in with the items above for $15, or sell it seperate for $25 shipped. Last I checked they were going for around $80 from several different vendors. Last edited by GEARBOXGARAGE; 02-11-2013 at 09:38 AM. |
02-11-2013, 12:11 AM | #11 |
02-11-2013, 09:37 AM | #12 | |
Thanks, Mike |
02-11-2013, 07:19 PM | #13 |
Found the frame bracket. It was tacken off of a '64. The brown that is showing where the paint chipped off isn't rust, it looks to be a red oxide primer. Wouldn't take much to sand blast and give a fresh coat of paint.
02-11-2013, 07:21 PM | #14 |
02-13-2013, 08:23 AM | #15 |
Pump Sold. I'll put up a new listing for the bracket. I have some parts going to powder coat soon, so I'll throw that in to have it freshened up.
06-10-2013, 08:04 PM | #16 |
hi capt ,i wanted to ask a ? i picked up this pump from gearboxgarage,, are there two styles of pulleys the chrome one that came w/it doesnt work ,it looks like to me it needs 1" or so back spacing to line up with the crank groove pulley it is a 2 groove it almost looks like a 2 grove p/s pulley off a long pump set up would work ? any help much appreciated mahalo hop
06-10-2013, 10:39 PM | #17 | |
60-66 Nut
Do you have a small block with a short water pump? Do you have the correct crank pulleys? I'm not aware of more than one single groove power steering pump pulley for the short water pump small block.
06-10-2013, 11:08 PM | #18 | |
,thats what i thought one pump pulley ,the chrome pulley i got with it is pretty much flat ,,there is a lot of room on hub of pump for a pulley with a small offset 1/2' maybe 3/4" ,when i get into the shop tomorrow i'll take a pic ,i got it installed thx a lot capnt aloha |
06-11-2013, 10:15 PM | #19 | |
06-11-2013, 11:59 PM | #20 |
60-66 Nut
You do not have the correct crank pulley. You need one with one more groove further out. The original pulleys had one groove right against the balancer. Then a space, and then a groove for the PS. The trucks that had AC used the middle groove.
06-12-2013, 12:46 AM | #21 |
thx bruddah was wondering i ordered it off ebay mistake ,,mahalo guess four eyes are better than two,,,oh u wouldn't happen to have one ?
06-12-2013, 11:39 PM | #22 |
60-66 Nut
I'll have to look and see if I have any extra crank pulleys.
Here is a nice made in USA 3 groove aluminum crank pulley. http://www.ebay.com/itm/Small-Block-...#ht_2243wt_786
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 06-12-2013 at 11:53 PM. |
06-13-2013, 06:06 PM | #23 | |
06-14-2013, 12:52 AM | #24 |
60-66 Nut
With the 3 groove crank pulley, you only use 2 of the grooves unless you have AC. The groove closest to the balancer is for the Alt, and the 3rd groove is for the PS pump. I'm not sure if the 2nd groove on a 2 groove pulley would be used for a air (smog) pump. I've never had a short water pump small block with the air pump.
06-15-2013, 08:15 PM | #25 |
Captainfab - thanks for steppin' in and helping out! Been busy and haven't had a chance to get back to this thread.
