laying low
![]() Join Date: Mar 2001
Tahoe has no rear heat
My '03 Tahoe with rear climate control is only blowing cold air.
I removed the temp door actuator and it was turned full to the cold side. I unplugged it, removed the cover and manually reset it to center then plugged it back up and it immediately turned to full cold again. For now I centered the actuator and left it unplugged so it does blow warm air. I found a thread on another site on this topic. Some say the module is bad, some say it was the actuator. How do I test the actuator to know that it is really bad? Or the module? I understand either of these will set a dtc but it's only detectable with something more than just the low end scan tool. I have an Innova tool. This is only and air distribution issue as there is plenty of hot water going to the heater core.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Re: Tahoe has no rear heat
GM has an updated control module that "usually" takes care of that. They programed out all the Over-travel logic DTC's in the module.
laying low
So since the actuator does move it is ok? We know it is a faulty module now?
I had that problem with my 2001 chevy tahoe the front would blow hot air and the rear cold. I disconnected the water lines to the heater core and put a water hose to clean it out. That worked for me. Might want to try it out.
Posted via Mobile Device |
laying low
Well I have it set to blow warm air and put it back together so she can run it. Would the parts stores have the updated modules? I really don't want to have to buy one from our local dealer.
#8 | |
laying low
The rear actuator numbers are: 16164972 green S bar code N3331533C 33518509 control module: Red Gray serial 0540 bar code 15185966 What do you think?
The updated module # is 15832319.
15185966 is the original out dated module. |
C35 Crew Dually
Where is the actuator flap on these? My truck does the same. Thanks
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
laying low
On the Tahoe and Suburban the rear heat/ac unit is behind the side panel on the right rear of the vehicle. Snap the trim loose and a couple of screws and pull the panel off. One door actuator is at the front and one at the rear and the control module is mounted in the center.
Still plays with trucks
Here you go. It is behind the actuator just to the left of the blower motor. The control module is the box with the two blue connectors about a foot to the left of that.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#13 |
I just posted more info in another thread.
http://67-72chevytrucks.com/vboard/s...3&postcount=14 Hope this can help somebody else out. No rear heat in the winter sucks for the kids. My temp fix cost nothing and can be done in a few minutes if the parts to fix it right are not on hand when you need rear heat.
