Old 11-04-2012, 07:14 PM   #1
56 Hauler
Carpet
Can anyone recommend a supplier for a good quality carpet kit to install myself ? I have a 65 pick up, Thanks for any advice
56 Hauler is offline   Reply With Quote
Old 11-04-2012, 08:39 PM   #2
kcsa75
kcsa75's Avatar
Re: Carpet
I used Stock Interiors -- http://www.stockinteriors.com. Couldn't be happier. Good quality, easy to install, etc.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 11-04-2012, 09:22 PM   #3
62 Barnfind
62 Barnfind's Avatar
Re: Carpet
Carpet looks good! How much was it?
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 11-04-2012, 09:59 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Carpet
I bought the full vinyl floor mat for my truck instead of carpet, but I also purchased from stockinteriors.com and was very pleased with the purchase. They sent exactly what I ordered and offered excellent order tracking and communications. If I ever switch to carpet I wouldn’t hesitate to buy from them.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 11-04-2012, 11:14 PM   #5
kcsa75
kcsa75's Avatar
Re: Carpet
I don't remember exactly, but $139 is sticking out in my mind. I actually bought it through Amazon.com because I had a gift card I could use. Look on their website, all the pricing is there.
Willie
'72 C10 Highlander
Old 11-04-2012, 11:34 PM   #6
MisterC
MisterC's Avatar
Re: Carpet
Did you get the mass backing? I'm ready to order and torn whether I should upgrade to that.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 11-05-2012, 09:58 AM   #7
kieth
kieth's Avatar
Re: Carpet
Before you install the carpet (or full vinyl floor) be sure and sound insulate your cab and add insulation. I did this with products from Home Depot and it makes all the difference in the world in the sound levels inside the cab. cost was about $ 2.50 per sq ft. Here are some pictures..
http://kieth.smugmug.com/Trucks/66-G...1244&k=x9L6d7w
http://kieth.smugmug.com/Trucks/66-G...8372&k=SDQRkDS
http://kieth.smugmug.com/Trucks/66-G...4752&k=HTG7Xwm
Here is a picture of the full rubber mat being installed, and after this we put a stock regular floor mat down to keep the look stock......
http://kieth.smugmug.com/Trucks/66-G...5324&k=TJ6s3L4
http://kieth.smugmug.com/Trucks/66-G...6070&k=VBbz2pG
The insulation and sound deadening will cost more than the carpet but the combination of both will make your truck as quiet as a church mouse.....
kieth is offline   Reply With Quote
Old 11-05-2012, 12:20 PM   #8
themouth1
Re: Carpet
What did you use from Home Depot? Dyna mat is expensive...
themouth1 is offline   Reply With Quote
Old 11-05-2012, 12:35 PM   #9
1963c-10
1963c-10's Avatar
Re: Carpet
x2
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-05-2012, 01:15 PM   #10
Ta2Don
Ta2Don's Avatar
Re: Carpet
what did you use from home depot? Dyna mat is expensive...
posted via mobile device
x3
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 11-05-2012, 01:18 PM   #11
lil_sahara450r
Re: Carpet
X4!
lil_sahara450r is offline   Reply With Quote
Old 11-05-2012, 06:06 PM   #12
kieth
kieth's Avatar
Re: Carpet
used 2 different products:
1. butyl rubber with alum like (dynamat) I could not find the stuff we used on the floor but will go by tonight and look, it was something like this but with aluminum on 1 side and glue on the other
2. Frigiking closed cell foam insulation with alum back
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Old 11-05-2012, 06:16 PM   #13
theastronaut
theastronaut's Avatar
Re: Carpet
I think it's called Peel and Seal or Quick Roof. Works great, I've done a few sets of doors with it and the difference in noise is very noticeable.
theastronaut is offline   Reply With Quote
Old 11-05-2012, 06:43 PM   #14
64fleetside
Re: Carpet
I put the same stuff in mine as Kieth and astronaut, works great. Was for roof flashing, IIRC-like for in between two different roof surfaces. Best improvement was behind the door panels.
64fleetside is offline   Reply With Quote
Old 11-05-2012, 08:36 PM   #15
themouth1
Re: Carpet
Alright...Another question...How did you use both of the products? Did you put one over the other? More details please. I have a carpet kit but have been waiting to put it down until I get this done...You also said it cost you about 2.50 a square foot. How many square foot of material did you use? Thanks,
Old 11-06-2012, 12:57 AM   #16
Reyals Bemus
Re: Carpet
Hey kcsa75,
Is your throttle pedal mounted like that from the factory? Meaning on a swing instead of to the floor. I want to install a swing type pedal in my '64 instead of the stock floor pivot but don't want some fancy aftermarket thingamajig either. Just want a factory looking and functioning swing away pedal.
Anyone know what I could use?
Reyals Bemus is offline   Reply With Quote
Old 11-06-2012, 03:02 AM   #17
MisterC
MisterC's Avatar
Re: Carpet
Markeb01's mod is the best one I've seen using the 71-72 pedal assembly. As always, his detail is second to none.
http://67-72chevytrucks.com/vboard/s...=444502&page=5
Old 11-06-2012, 10:30 AM   #18
kieth
kieth's Avatar
Re: Carpet
I put the sound deadner down first, sealed it with silver tape, then put the insulation over that. I think the whole project cost about $200.00 but it is worth the expense. .....Could not get by home depot will try and do it today...
Old 11-06-2012, 10:37 AM   #19
kieth
kieth's Avatar
Re: Carpet
Originally Posted by Reyals Bemus View Post
Hey kcsa75,
i USED THE STOCK ONE but you could grab one out of a 91 burb or a 87 pickup, they do not attach to the floor.......Kieth
Old 11-06-2012, 02:47 PM   #20
themouth1
Re: Carpet
Thanks! I may do that this weekend.
