Ball joint/Tie rod end /McGaughy spindle confusion/help request
Hi all,
I searched but I couldn't a specific answer for my issue. I recently bought my 65 GMC. While picking up parts to upgrade my power steering a craigslister also stated that he had 2.5" lowering spindles that "he was told" would fit a 63-66 Chevy truck. So I took the bait and got them. They are the McGaughy spindles with the 6072 L & R stamped on them. I called McGaughy's and was basically told to try the ball joints to see if they fit. Here is where I have run into issues. First off, I am not very familiar with how ball joints are supposed to fit into spindles. I have tried 3 different upper ball joints: one for 63-66, one for 71-72, and 73-86. The ones for 63-66 and 71-72 would not fit at all - too thick. The '73 ball joints appear to fit perfectly. ![]() My issue is the tie rod ends. As stated on the Drums to Discs conversion thread, I was planning to use the outer tie rod ends for the same years as the ball joints, however, the outer tie rod end for a 73-86 does not fit at all! It is too large. The threads won't even go in the hole. I bought a new tie rod end for a 63-66, however, and it fits perfectly. Has anyone run into this type of situation? Do I just change the ball joints out to a 73-86 version and run my existing tie rod ends? Seems like the easiest solution but I want to make sure I am not missing any issues. Here is a pic of one of the spindles: ![]() Gratuitous truck shot: ![]() THANKS A MILLION!!!! John |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Ball joint/Tie rod end /McGaughy spindle confusion/help request
I'm not that familar with their spindles, but if that is what fits, that's what I would use.
