Old 11-04-2012, 10:50 PM   #1
funtruck1964
tack
i don't know what this tack was in orignally i took it out of my 67 landcruiser $50.00 local pick up only.
funtruck1964 is offline   Reply With Quote
Old 11-04-2012, 11:06 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: tack
Very cool. Your tach is a standard aftermarket Sun unit that could have been purchased new for anything with matching volts and cylinders. It probably dates to around 1965 because the head has the zero adjuster button on the front. The pinch cup it’s mounted in had been around since the mid-late 50’s and was falling out of favor by the time the black dot appeared on the face.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 11-04-2012, 11:12 PM   #3
funtruck1964
Re: tack
thanks for the education i kinda thought it was aftermarket.
Old 11-04-2012, 11:24 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Re: tack
Here's an earlier thread you might find interesting:
http://67-72chevytrucks.com/vboard/s...sun+tach+retro
Old 11-05-2012, 10:21 AM   #5
kieth
kieth's Avatar
Re: tack
Here is a earlier version that I used......it was a truck tack so that is why the rpms only go to 5000
http://kieth.smugmug.com/Trucks/66-G...mmMg&lb=1&s=XL
I had it updated with new internals that did away with the old transformer box........Kieth
This tach was stock in the GMC's as well as the sun batometer....
kieth is offline   Reply With Quote
Old 11-05-2012, 04:59 PM   #6
chevyrestoguy
chevyrestoguy's Avatar
Re: tack
Does it work?
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 11-05-2012, 08:10 PM   #7
funtruck1964
Re: tack
it was in a project fj40 that was a basket case so i never tried
