Old 11-04-2012, 11:07 PM   #1
ybnaford
Junior Member
ybnaford's Avatar
04 4x4 Front Axle Seals Leaking
Right before my hunting trip last week I did the normal routine service and noticed while under the truck that the axle seals were leaking on both sides. I did not want to see that, but being an 04 with about 150k miles I guess it was inevitable. My questions are: Is the front axle pretty easy to remove without dropping out the entire front end? And, is breaking down the axle to get to the outer seals easy to do as well? I have done just about everything there is for a shade tree mechanic to do on routine replacement items but have never taken out an IFS axle to be serviced. Any thoughts on this would be appreciated.
04' Silverado 1500 ExtCab, 4x4, SWB - 240,000 & still Going, 62' C10 SWB, Stepside - Ole Green Girl!
ybnaford is offline   Reply With Quote
Old 11-12-2012, 08:49 PM   #2
psuedopimp
psuedopimp's Avatar
Re: 04 4x4 Front Axle Seals Leaking
i was wondering as well....my 2001 tahoe has a leaky passenger side....doesn't look as bad as yours but it needs to be addressed.
psuedopimp is offline   Reply With Quote
Old 11-13-2012, 09:27 AM   #3
truckdude239
truckdude239's Avatar
It has to come out and be taken apart i believe
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-17-2012, 12:23 PM   #4
1978steven
1978steven's Avatar
You can do it without pulling the diff, and honestly im not sure if it makes it any easier of a job just by pulling the diff. Those snap rings that hold the axles in are very tough.
Here's how I did mine:
Pull the cv's, next you'll have to beat the axle shafts outward to get the snap rings to release and remove them from the housing. At each end of the shafts are machined groves that a spring tensioned snap rings holds them in place in the carrier and are very difficult to get them release tension. The drivers side for me was slightly easier to get out then the passenger side but both are a pain the butt to get released. On the passenger side you might end up having to take the tube off the center section as I did. The whole job is a royal pain....
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline   Reply With Quote
