Old 11-04-2012, 11:26 PM   #1
77c10
77c10's Avatar
700r4 swap bracket question
I am in the process of putting a 700r4 in my 77. What kind of tv bracket have y'all used? I am running a Holley carb. Also, has anyone used a geometry correction bracket?
Thanks!
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 11-05-2012, 02:18 PM   #2
MDc10
MDc10's Avatar
Re: 700r4 swap bracket question
Thanks!
I actually just went through this same problem. I used a bracket out of jegs and had to buy a extra 700r4 adapter kit. It ran around $20 or so. I had to modify mine to fit on my cable. Bad thing was when I stepped on the gas the cable bracket moved. Kind of a poor design. It bolts on through 1 carb bolt. I'm in the process of welding up a small bracket now to bolt on it to keep it from moving.
MDc10 is offline   Reply With Quote
Old 11-05-2012, 02:19 PM   #3
MDc10
MDc10's Avatar
Thanks!
forgot to say I did use a geometry correction bracket, and to be honest it looks worse off than it did. But it took it to a tranny shop and he swears I need it.
Old 11-05-2012, 02:31 PM   #4
MDc10
MDc10's Avatar
Thanks!
page 13 about half way down, titled tv cable mounting bracket. I asked the same question a few weeks ago. I'm computer illiterate so.i don't know how to post links. Maybe that will help. A few guys posted pics of the same bracket and some of there set ups
Old 11-05-2012, 10:36 PM   #5
clinebarger
http://www.bowtieoverdrives.com/cata...php?ITEMID=217
clinebarger is offline   Reply With Quote
Old 11-06-2012, 08:33 AM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Here is the best bracket I found. It's from Edelbrock.
http://rides.webshots.com/photo/2083...54440533NjEHgc
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
