Old 11-04-2012, 11:57 PM   #1
Boosted1984Silverado
Headlights
Hey guys. Anyone know if they make an aftermarket set of headlights that are any brighter (to replace the four on the front), or a lot brighter, than the factory set? If so, can you tell me where to find them an a possible cost? Thanks much.
Boosted1984Silverado is offline   Reply With Quote
Old 11-05-2012, 12:43 PM   #2
Edahall
Re: Headlights
Yes, here you go.
http://www.autotoys.com/x/product.php?productid=550
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 11-05-2012, 01:02 PM   #3
Evil Trailblazer SS
Big Gulps Huh? Whelp...
Evil Trailblazer SS's Avatar
Re: Headlights
Sylvania's Silverstar replacement sealed beam lights make for a great upgrade as well. The Hella conversions are the ultimate but for $200 plus the cost of a relay harness system, I don't think most people would find it to be a worthwhile upgrade.
"The Ghost II" - 1987 V30 CC, 14-BFF (2nd Design Heavy Ribbed HD) SRW Conversion, 454/4L80E/205, 6" Springs, 35" Toyo MT's on 17" Classic II's, Full Audio System, Lot of Other Goodies!
Evil Trailblazer SS is offline   Reply With Quote
Old 11-05-2012, 01:26 PM   #4
Edahall
Re: Headlights
Yes Hella's are somewhat costly but it can be done for significantly less than $200. Instead of replacing all 4 headlights, replace just the 2 driving lights ($100). For the high beam headlights, wire the hi/lo filaments together so they both come on at the same time. That makes them approximately 100 watts each.
There are wiring diagrams that show how to make your own relay harness. It took me a little time but saved a lot of money.
Old 11-05-2012, 01:31 PM   #5
trivon56
trivon56's Avatar
Re: Headlights
Do they make any headlight conversions for the round 7 inch headlights
trivon56 is offline   Reply With Quote
Old 11-05-2012, 01:37 PM   #6
Re: Headlights
Thanks for the responses gents. I just hate going down the road at night and seeing a "dim yellow hue" when compared to some of the more modern lights on the road today.
Brent
Old 11-05-2012, 03:46 PM   #7
earnhardtgm3
earnhardtgm3's Avatar
Re: Headlights
I use these on 79 Z/28 and my 77 Chevy truck and both use relays for more voltage to them as well.
Headlights
http://www.rallylights.com/detail.aspx?ID=136
Relay kit--
http://www.ebay.com/itm/New-Headligh...06a8b0&vxp=mtr
1977 Chevrolet Scottsdale:
1979 Camaro Z2/8
http://www.nastyz28.com/forum/showthread.php?t=129623
earnhardtgm3 is offline   Reply With Quote
Old 11-05-2012, 04:54 PM   #8
king-918
king-918's Avatar
Re: Headlights
Jeep lights will work check eBay. H.I.Ds are the only way
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 11-05-2012, 05:15 PM   #9
egaray281
egaray281's Avatar
Re: Headlights
they have the housings on lmc, i actually found mines at a flea market i got them for $40 then i just bought some HID's for another $45, they make them for the round and square headlights
egaray281 is offline   Reply With Quote
Old 11-05-2012, 06:14 PM   #10
trivon56
trivon56's Avatar
Re: Headlights
I have the hid boxes just no the bulbs and lens. Is there a place I can get let unsealed lens and what bulb works for high and low beams I was also thinking of doing my fog lights in hid also. And ideas.
