11-05-2012, 12:23 AM | #1 |
how much?
hey everyone. was curious as to the horsepower this roughly would make?
80's stock bore 4 bolt main chevy 350. 3 speed saginaw converted to floor shift summit racing k1103 cam Cam Style:Hydraulic flat tappet Basic Operating RPM Range:1,600-5,200 Intake Duration at 050 inch Lift:214 Exhaust Duration at 050 inch Lift:224 Duration at 050 inch Lift:214 int./224 exh. Advertised Intake Duration:272 Advertised Exhaust Duration:282 Advertised Duration:272 int./282 exh. Intake Valve Lift with Factory Rocker Arm Ratio:0.442 in. Exhaust Valve Lift with Factory Rocker Arm Ratio:0.465 in. Valve Lift with Factory Rocker Arm Ratio:0.442 int./0.465 exh. Lobe Separation (degrees):112 flat top pistons cloyes gear drive stock 993 heads garage ported edelbrock performer intake 4 barrel qjet carb hei with petronix module hooker super comps 2.5" stainless piping with x pipe flowmaster 50's i read this engine makes 250 hp stock and 304 ft/lbs tq. curious to see what it makes with these upgrades. will my compression be too high with the flat top pistons? |
11-05-2012, 02:02 AM | #2 |
BlahBlahBlah
Re: how much?
Im not an engine building expert at all, but I think flat tops are the way to go. If you had domed pistons I believe your compression would be too high.
As far as the rest of the build I have zero idea...except gear drives are cool for awhile, you may tire of the noise (if its a noisy square cut gear one) my brother has one in his 65, cool at first lol.
11-05-2012, 09:24 AM | #3 |
Re: how much?
some people like them some dont I had one in the camaro and got tired of it quick i'm another no Idea what kinda power it would make but it sounds like a solid build
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
