Mounting coil to firewall?
I have 58 with v8 283. the coil that is now mounted to the intake is getting in the way even though it has a factory bracket. Was the coil ever mounted to the firewall? If so,where? Any pics out there?
Thanks Posted via Mobile Device |
Re: Mounting coil to firewall?
No, but its your truck mount it where ever you want. Most aftermarket ignitions end up on the firewall or fender, just keep it out of the heat and check to make sure rain water does not run on it when you open the hood (early corvettes had a shield over the distributor for that purpose).
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
I always mount mine on the firewall near the dist.
#4 | |
on those cars and not as water shields. Without them there was too much static in the radios on the early Corvettes. The covers were used on up into the 70's with point type ignition. Other than being clutter on the firewall there is no reason not to put the coil on the firewall. On my T bucket that I built in the 70's I put the coilon the inside of the firewall and ran the wires through a grommet to the distributor. It worked good and kept the clutter down. |
I once mounted a divorced style HEI coil on the firewall of a 67 Chevelle and I could hear every single spark as it occurred. No, the coil wasn't bad. It was the CDI type multi spark ignition system driving the coil that caused it. Never did try and put a radio in that car.
u can put a coil anywhere, just make sure u have a real an i mean real good ground, i try an hide all mine that i install just to make people wonder
Mr48 thanks for the clarification, learn something everyday here.
#8 | |
