Old 11-05-2012, 04:46 AM   #1
jjtackleberry
jjtackleberry's Avatar
Tilt column question
I have seen people talk about a "true truck" tilt column.
Is there a way to tell if a column is a "true truck" tilt column. Getting ready to buy one, thats not in a truck. I want to make sure i'm getting what i think
thanks
'71 Chevy LWB all OG
'86 Chevy LWB all OG
It's all a matter of perception
jjtackleberry is offline   Reply With Quote
Old 11-05-2012, 06:43 AM   #2
JimKshortstep4x4
Re: Tilt column question
One way to tell is the truck tilt has the slot for the neutral safety switch located on the lower end of the column, (approx. 7" from the end). The van tilt has the slot located higher up close to where the column is mounted in the dash.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-05-2012, 10:48 AM   #3
29od1
A van tilt also has a longer inner shaft that stick out about 3-4 inches longer than the truck.
An RV tilt looks exactly like the truck, as far as the location of the NS switch and length of inner steering shaft. The only difference in the two is that the RV shifter shaft arm (located on the lower part of the column) has a joggle in it, where as the truck shifter arm is straight.
29od1 is offline   Reply With Quote
