67-72 coil suspension Dana rearend??
Came across a truck that my buddy was telling me he thought had a 10bolt rear. I told him these trucks were 12 bolt rears or Dana's in HD app's. Since this was just a C10, I told him I'd look myself & verify.
It definitely isn't a 12bolt & has a Dana housing. What different levels of the Dana housings were available? What about their strength vs the 12bolt?
Active Member
![]() Join Date: Feb 2012
Re: 67-72 coil suspension Dana rearend??
Hi Everyone, If it helps - my 1968 GMC 1/2 ton leaf spring truck has the original Dana44 ten bolt rear, 355 gears......no problem with durability. Works good.
See that's what I assumed it was (a Dana 44). Im curious what possibilities there were. He took a pic of it & someone else 'confirmed' it was a 60. I'm not so sure....
I've seen a few GMC 1/2 tons with Dana 44's in the rear.
mine has one as well but is leaf spring as well. No reasone to believe that they couldn't have been had in a coil rear. Heres a 67 spid with the option code for the dana 44 rear in a half ton. J04 was spicer 44 and J07 was spicer 60.
It could be a Dana 60 6-lug. I don't believe I've ever known of one as late as a '71 that had a Dana 60. They are rare to find,so maybe there were 5-lus and I've just never come across one. I want one,too! Eventually I'm going to get a kit from www.markwilliams.com to convert a 3/4t coil rear.
If it's a Dana 44,that's a cool little detail to be different. But,in reality,they are about dead even with the 12-bolt for strength...no real advantage
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-06-2012 at 07:56 AM. |
#7 | |
My research shows the 44's to have a 8.5" ring gears; the 60's have 9.5" ring gears so a definite difference/advantage. He purchased a big brake kit for a 12bolt so he can't use the rear. I'm just trying to determine what it actually is. I looked @ the SPID label & didn't see anything special concerning the rearend codes. I tried to take a pic of it but the glare wouldn't allow a quality pic.
not sure of all dana diffs but mine has 44 casted right into the housing. Maby check yours and see maby it has a 60 casted into it.
I knew the newer Jeeps had the model # cast into the housing web material & learned yesterday that it was common for the older housings as well. I'll suggest to my buddy to clean it up a little & take a look (it was pretty gunked up the other day so I didn't see anything when I looked @ it w/him).
"Ochre Ogre"
I have one Dana 44 3.54 with Power-Lok that came out of a 68 GMC V6 and one Dana 60 3.54 w/ Power-Lok that came out of a 68 GMC Suburban ambulance with a 396. Both were half ton GMC trucks with 6 lug axles.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
Chewy is right. The model should be embossed on the housing. The physical size difference is pretty obvious. A Dana 60 is way bigger than a 12-bolt. A Dana 44 is about the same,but obviously shaped different.
Were both of those leaf spring? I have only seen the Dana rears in GMCs. I have seen GMC coil rear Danas,but that is one rare bird to find (and I want a coil 60 something fierce!). If that Dana 60 is a coil rear I'd like to talk to you about that thing
He said he scrubbed the dirt off & it has 60 stamped in it. I'm going to look @ it again because it didn't look physically larger than a 12bolt which is why I thought it was prob a 44.
For some reason, he no longer wants to swap me for a 12bolt (he thought it was a 10bolt originally until I mentioned it was a dana). Should of kept my mouth shut ![]()
#13 |
Doesn't he know? Danas suck,man. They only used them when they ran out of Corporate rears. Tell him I said so. They rob power. Boat anchors. Oh yeah,and parts are impossible. Honestly,the 6-lug Dana 60 brake parts are probably about impossible (don't mention disc brake conversion).
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-08-2012 at 08:31 AM. |
#14 |
Grandpa in the rustmobile...
orangecrush (kid from TX with orange lwb truck) had a coil spring dana in his 1/2 ton truck.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#15 |
I have seen a coil spring Dana 60 in a '70 c10 but assumed that it had been swapped from a leaf spring truck...should have looked closer at the truck because it was for sale.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#16 |
Junior Member
I had a 69 half ton with a Dana 60 rearend. A bearing went out and ruined the axel. I could not find a replacement so I went ahead and switch to a five lug 12 bolt.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
#17 |
There were definitely Dana 60 6-lug rears,but I've never seen a 5-lug. I have only seen the Dana 60 in GMC 1/2 tons. Were these last two trucks Chevy or GMC?
#18 |
Junior Member
Mine was a chevy. It was ordered that way I believe.
#19 |
so easy a caveman can do it...
![]() Join Date: May 2006
I hava a 12 bolt rear with 3.73 gears and posi-trac on coil springs under a 69' half ton. I think this is a Dana rear...any ideas?
oh yeah...it's 6 lug. Last edited by Sequoyah; 12-17-2012 at 11:59 AM. Reason: ... |
#20 |
![]() Join Date: Mar 2000
The 67-68 GMC1/2ton 6lug Dana rearend in question is a Dana 60-35 (AKA-Spicer)
this rearend is a Dana 60 with a semi-floating axle shaft where as a standard Dana 60 is a full floating axle shaft . They also used a Dana 44 in the 67-68 GMC 1/2tons. The Dana 44, Dana 60-35 were only used in models with rear leafs. Paul @ GMCPauls |
#21 | |
Paul @ GMCPauls |
