70-72 body on 73-80 chassis???
Hi Everyone,
has someone done a swap like this? and if so, what is involved? I assume different cab mounts on the frame. But will the older style body fit on the newer style frame? Does the wheelbase match? And can I reuse my steering stuff etc? Thanks for your help! K20chevy |
resident wrencher
Re: 70-72 body on 73-80 chassis???
I know the beds kinda line up
Posted via Mobile Device |
a local going is doing it. the frames are pretty similar. i dont think the wheel base is the same though
nah 67-72 115" and 127" 73-87 117.5" and 131.5" nothing that cant be corrected
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
So if my truck originally has the 131.5" wheelbase and the older style I would use the body from has 127", I would have a larger gap between the cab and the bed? It probably depends on the location of the wheel opening too, right?
I thougth the frames are kind of the same, but Iīm sure the body mounts are different. @ cord d: is there a way you could find out from that local what would be involved? Iīd appreciate that a lot! Thanks! |
Gettin It One Pice At A Time
Nvm, I am dyslexic. ROFL
RIP ELJAY ![]() ![]() Getting the truck done, one piece at a time. You can tell a lot about a fellows character by his way of eating jellybeans.Ronald Reagan I dont know the key to success but I know the key to failure is trying to please everybody. Bill Cosby |
Well, the reason is, I always wanted a 70-72 truck but couldnīt find a good one to build. Up in the north east, it is almost impossible to find one. So I found the 78 K20 I have been building since. I still would love to have a 70-72, but the chassis on my has been modified so much that it would be a ton of work transfering everything to another truck. Therefore the idea was to keep my chassis and swap bodies insted of building another truck. But maybe once I finish the 78, maybe I just build a 70-72 anyways.. maybe that simpler than swapping things around... What do I know!?
#7 | |
![]() Join Date: Apr 2009
![]() Posted via Mobile Device |
@ meter swinger: x2!! BUT the wife is one thing and running out of room to park them all might pose a problem too. I already have 2 cars, a Jeep and a full size truck. Anotherone would make it really difficult to keep the wife and neighbours happy...
![]() Join Date: Oct 2009
The firewall forward I believe is the same. Crossmembers can be swapped. The rest of the frame is different. As far as wheel base, get out the tape measure and check.
@74 stepside: Thanks for the info. Iīll measure mine when I have a minute.
Very very cool, and thanks for the lesson! I love your unique ink!
I guess Iīll leave my 78 body on my truck after all and just buy a complete 69-72 truck at some point...
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104 68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441 |
#13 |
But just out of curiosity, if someone was to swap a early 70īs body on a 78 chassis... how would you legaly register it? As the early 70īs truck cause it has the vin and cab from that truck? Or the 78 truck cause the chassis and numbers are from the 78.... obviously the numbers on the frame wouldnīt match the vin in the cab.... does anybody know how this can legaly be handled???
#14 |
anybody? Would it be better to regster it by the vin in the 70-72 cab then??
#15 |
This would be a WAG, but the cab. Make a pot of coffee and call DMV to make sure. I know in Maine, swapping later cabs onto earlier chassis was common, especially among friends that used to plow. But these were straight swaps, like '80's cab onto '70's frame.
Talk to your local inspection guy also, if anything has to be fabricated, it could get failed for that. Unless the mechanic is a "turn on the lights, honk the horn" inspector...
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
#16 | |
#17 |
There is a number on the frame, however I'm not sure exactly where. Shows you how many times over the years mines been checked. Thinking about it, buddy's fixing an old plow truck prob didn't care. Prior to me buying my plow truck, it hadn't been registered for 5 years. But still worked every storm. PO thought he'd "roll the dice."
That's why I'm unsure exactly what's required.
#18 | |
#19 |
No prob. Lived in the Augusta area for about 25 yrs. Dealing with DMV, inspections/state police requirements can be a pain.
#20 | |
#21 |
78K & 79C Jimmys
depending on how/why you are pulled over ,it can be fines,seized and towed up here.
impound fees while they "sort it out",and the fines go up on a scale of "involvement" keep it legal
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#22 |
![]() ![]() Join Date: Jul 2002
Besides some of the stuff already mentioned, one big thing is the frame kick-up for the gas tanks. You will need to do a body lift in order for the 67-72 cab to clear the kick-up on the 73-87 frame.
#23 | |
![]() thanks for pointing out the frame difference!
#24 | |
What is wrong with the original frame? You can take everything off the 73-87 and pretty much bolt it to the original frame, then you won't have to deal with all of this mess.
#25 | |
Problem is, on my truck, basically NOTHING is stock or original..that makes it difficult.
