Old 11-05-2012, 02:30 PM   #1
Project restore Hope
71 Cheyenne restoration
I am new to this site and I wanted to get some advice about my truck. I will post some pictures later today. I have a 71 C10 Cheyenne that is in fair shape. When I bought the truck it wasnt running and it had been sitting for a while. I replaced the Carb, spark plugs, vaccum advance, fuel pump, fuel filter, points, and bam the truck runs, a little better after I got the timing right its got a 350 with the th350 trans. My main concern is the rust, mainly because I have not done much body work in the past. I have a few ideas for her, but I wanted to get some ideas from y'all.
Project restore Hope is offline   Reply With Quote
Old 11-05-2012, 02:52 PM   #2
1972SUPERSB
1972SUPERSB's Avatar
Re: 71 Cheyenne restoration
Welcome to the site! There is lots of good information here and good people to help. I just got my 72 cheyenne super not to long ago as we'll. Not sure what your plans are for your truck? O yeah pics are always welcome!
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 11-05-2012, 03:28 PM   #3
RenoKeene
Florida Edition
RenoKeene's Avatar
Welcome from Central Florida!
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 11-05-2012, 05:02 PM   #4
Lee H
Lee H's Avatar
Welcome aboard!
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 11-05-2012, 05:09 PM   #5
no moa
no moa's Avatar
Welcome from Maine.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 11-05-2012, 07:14 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
from the Heart of Arkansas!
Bodywork.....the bane of our existance. The newest versions of the 67-72's are now essentially 41 years old. Normal wear and tear, mud, snow, coastlines all add to the possibility of rust. Rockers, cab corners, cab mounts, inside of the wheel openings, rear quarters....all are subject to rust. The inner fenders, especially beneath the battery are prone to rust. The radiator support panel is another place to check. The kick panels are especially prone to rust, causing water to leak into the interior. The cause is dirt, leaves, pine needles, etc., that accumulate in the plenum after passing thru the grille in front of the windshield. There have also been numerous cabs that have rust in the header above the windshield. So, check carefully.
Member Nr. 2770
Old 11-05-2012, 07:29 PM   #7
cerjio
Well if you truck needs the normal stuff replaced because of rust an dont have the money to pay somebody to do it , you will have to ask your self how much you want to do ? most stuff is fairly easy to do if you have a few skills . Where I live the local college has a body shop course you can take during the evenings an you can do it yourself . I took an autobody course several years ago , an used what limited weilding skills I had an learned to do it myself. An now have a nice 70 chevy pu to show for it , no its not a show truck compared to many but I did take it to shows an can say I did it myself.
alot of people on here are willing to help , either with advice or in trade , or just plain help when they can . ENJOY AN HAVE FUN !
cerjio is offline   Reply With Quote
Old 11-05-2012, 08:49 PM   #8
whoryou1979
whoryou1979's Avatar
Welcome. I bought my truck, and was in the same position as you. Never done a days worth of body work, or welding. I just decided to suck it up and get to cutting and measuring. I replaced the outer cab floor/inner rockers, outer rockers, and cab corners. I am happy with the results, and it sure beats the cost of having someone else do it.
All Day Every Day
'72 C20 Cheyenne Custom Camper
http://67-72chevytrucks.com/vboard/s...d.php?t=549132
whoryou1979 is offline   Reply With Quote
