Ignition cylinder removal-lost key.
Good to be here,looks like anything I'll ever need to figure out could be solved with the help of someone here.Heres my first challenge for you,how the hell do I get the cylinder out without a key?I bought the truck [70 c-20] drove it awhile,enjoy the torque,sound,feel and look of it,staight body 350/350 top to bottom chevy orange in color...discovered an oil leak,raised the motor,droped the pan,pulled the timing cover,replaced the seal,got a one piece 'sure dry' gasket for the pan,put a new motor mount on pass side,new fine thread grade 8 bolts for the mount brackets,torqued everything back together,inch and foot lb....lost my damn key....I put wire in the hole to try and disengage it,tryed unscrewing the outer bezle,the cylinder keeps it locked in...any solution?
Registered Cruiser
Re: Ignition cylinder removal-lost key.
If it's an old worn switch, it should be easy to pick. There are videos on youtube that will show you how.
I intend to live forever. So far, so good. |
Thanks for the tip...you folks don't waste any time helpin out.....
Take the passenger door lock and send the numbers on the back to LocDoc on the board here and he can make you a new key.
69 Chevy 4x4 383 Power ![]() |
The Older Generation
Like Jason said look for a code number on the passenger door lock. Read through this thread. Read the whole thing before you try anything suggested in it. http://67-72chevytrucks.com/vboard/s...d.php?t=462981 LockDoc
I payed a guy to replace the ignition.
Posted via Mobile Device |
The smith had the master for my truck.Cost me $100.
#8 | |
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-12-2013 at 01:49 PM. |
