64 suburban
A buddy of mine in texas gave me his 64 suburban back in the spring. Being from cincinnati I wasnt able to go get it until a few weeks ago. It is a 292 (I guess) with a automatic. I got it running and had to put a water pump on it but it sounds good.
The problem I have now is the fuel tank. He had quit driving it because the tank had a leak, so it has sat for a few years and the tank is VERY nasty inside. I might attempt to clean it but if I could find a replacement I would go that route. It seems most of the vendors list tanks for trucks but not the suburban, Is there a truck tank that fits this vehicle? |
![]() Join Date: Mar 2010
Check the classifieds on this forum. There is one over there for sale.
65 burb On the road Mar 26th Finally |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: 64 suburban
you could also contact David Boyd on this forum, he makes tanks. he could make one that would fit your sub easy.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Just here to tinker
![]() Join Date: Jun 2008
Re: 64 suburban
The suburban tank is a special beast. You can check out my build thread in my sig. And on page two or three I have good pics and explain everything I went through to get it restored.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
![]() Join Date: Sep 2011
Re: 64 suburban
I used a gas tank from a Blazer, more info is in my build thread too.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 64 suburban
I agree
Unless you want to be able to mount your spare tire in the factory location, I would just get a '69-'72 Blazer tank. It is nearly identicle, except for the lack of the spare tire indentation. Plus you will gain a couple gallons of capacity. This is also what is used in the rear tank conversions for the pickups.
Re: 64 suburban
A rear tank kit for pickups is what I used.
