Old 11-06-2012, 09:17 AM   #1
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Air-Lift for our truck
__Does anyone know where I can find a set of Air-Lift bags for a '70 coil spring rear? I have 4" drop springs and I would like to have the bags to use when loaded or trailer pulling. Looked at Air-Lifts website and they don't list anything for my '70 stepper. Not looking for trick stuff, just a basic overload set-up.
TobyArnot is offline   Reply With Quote
Old 11-06-2012, 09:41 PM   #2
Andy4639
Old member
Andy4639's Avatar
Wink Re: Air-Lift for our truck
Rob I used a set of jeep bags with extra spacers.
Ran the 2 air lines back to the bumper and used the Schrader valves to hang the tag with.
http://67-72chevytrucks.com/vboard/s...d.php?t=425850
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-07-2012, 05:08 AM   #3
SS Tim
SS Tim's Avatar
Went through this a couple of months ago.
http://67-72chevytrucks.com/vboard/s...d.php?t=537391
From what I was able to find they only have a 2wd Blazer listing posted. That should be the corrrect application for a C/10 as well. Poster never followed up so you get to.
http://shop.airliftcompany.com/produ...G_LEVELING_KIT
SS Tim is offline   Reply With Quote
Old 11-07-2012, 08:15 AM   #4
TobyArnot
TobyArnot's Avatar
Thanks guys for the responses. Andy , are those rear spings dropped or stock? And Tim, I may pursue the link further.
Again thanks,
Robbie Robinson a.k.a. TobyArnot
MY MOTTO:
Eat it all up, Wear it out,
Use the last few drops,
Spend all you've got,
Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life !
Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee)
Old 11-07-2012, 09:29 AM   #5
bk2life
super easy, buy the parts make it work. air bags are very easy going
bk2life is offline   Reply With Quote
Old 11-07-2012, 04:38 PM   #6
Andy4639
Old member
Andy4639's Avatar
Talking Re: Air-Lift for our truck
Yes droped springs. I got tired of it bottoming out with them. They have hardley any stiffness to them. The air bags make for a very nice ride now.
Old 11-07-2012, 08:22 PM   #7
Andy4639
Old member
Andy4639's Avatar
Here is the post. It took me a while to find it but here it is.
Old 11-07-2012, 08:27 PM   #8
Have you tried talking to them? I know for a fact that they used to have them for these trucks. I ran a set in the rear of a '70 Custom/10 I had. I got them through the spring shop I've dealt with forever.
Old 11-07-2012, 08:37 PM   #9
99-LS1-SS
99-LS1-SS's Avatar
Andy, thanks for the information and part numbers. I will likely need this since I plan on hauling my boat with a 4/6" drop.
My 1972 2WD Blazer build
1984 K10 beater truck
99-LS1-SS is offline   Reply With Quote
Old 08-24-2014, 09:46 PM   #10
JonnyC10
What keeps the bolts holding the spring cups in from puncturing the top and bottom of the bags?
JonnyC10 is offline   Reply With Quote
Old 08-25-2014, 09:16 PM   #11
TobyArnot
TobyArnot's Avatar
I'll jump in here. If you look at Andy's photos, you'll see one black spacer below the bag, and two spacers on top. The bags we both used are for a Jeep and are fairly short. The spacers have a large hole in the center and they keep the bags away from the bolts.
MY MOTTO:
Old 08-25-2014, 09:41 PM   #12
JonnyC10
Ok. Sweet! Thanks. Where would I get the extra spacers or do they come with the kit?
Old 08-26-2014, 06:16 AM   #13
TobyArnot
TobyArnot's Avatar
Not sure if "Air Lift" can supply them. I made mine from some 3" UHMW stock that was "hanging around' at the shop where I used to work. I made each one 1" thick x 3" dia. with a 1" hole in the center, and added a notch in the top one for routing the air line out. I had some pics somewhere, but I can't seem to find them.
Old 08-26-2014, 09:40 AM   #14
TobyArnot
TobyArnot's Avatar
Found the pics.
