Old 11-06-2012, 03:01 PM   #1
Nitrousbob
What do I have (suspension)
The truck used to be a 2wd, the last owner converted it a while back
My end result is I want another 4" in height and a softer ride, its a 3/4 ton right now and I dont do any towing
Here is a couple pictures, It looks like 4" blocks in the back, and the front springs look almost flat across, i believe the front suspension was taken from a suburban?
I was looking into a tuff country 4" lift, I just dont know if the rear springs would be the right height if I just went to the 4x4 springs with 4" lift , same question with the front.
not to mention replacing the 2piece driveshaft
Nitrousbob is offline   Reply With Quote
Old 11-06-2012, 05:10 PM   #2
b454rat
Re: What do I have (suspension)
It looks like the truck has 4" on it now. The front springs are soft rides, or they wouldn't be arched like that. If you want more lift, gotta go with 6 or 8". If you go with 6", you can use your stock steering setup, go bigger really should go with crossover...
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 11-07-2012, 05:10 AM   #3
Nitrousbob
I just thought with front springs like that , it would be 0" and the back was compensated from being a low 2wd truck? idk , its definitely shorter than other trucks ive seen with 4" lifts or it seems that way. thanks
Old 11-07-2012, 08:06 PM   #4
MTCK
MTCK's Avatar
Those don't look like 4" front springs to me... Maybe 2"? That would make more sense with a 4" block leveling out your 2wd rear.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 11-07-2012, 08:42 PM   #5
Mike C
Mike C's Avatar
Looks like a 2 1/2" lift to me. You can see the part # on one of the leafs around the spring eye. Google that #. Looks like Rancho but they kind of all look the same. Driveshafts should be fine with a 4", but chances are would need lengthening with a 6".
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
