Old 11-06-2012, 07:59 PM   #1
savatreatabvr
savatreatabvr's Avatar
Mr. Gasket Carb Base Plate Installation?
I bought a Mr. Gasket Carburetor Adapter Kit from Checker Auto and on the back it says "ADAPTS SQUARE FLANGE CARBURETOR TO QUADRAJET SPREADBORE MANIFOLD"! That makes me believe I can use this to mount my Squarebore Edelbrock 1407 carb to my factory 454 Spreadbore intake manifold but the adapter looks like it's a Spreadbore to Squarebore! Can somebody set me straight?
savatreatabvr is offline   Reply With Quote
Old 11-06-2012, 09:45 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Mr. Gasket Carb Base Plate Installation?
Take the ugly end and point it down and the round 4 hole side up. Spray toilet water on it and install carb add fuel and be amazed at how easy it is to get to idle without hardly doing anything cause its a edelbrock
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-06-2012, 11:52 PM   #3
savatreatabvr
This is the one I bought, looks like pic #1 is the top which would make it an Spreadbore to Squarebore adapter, am I right?
Old 11-07-2012, 01:07 AM   #4
INSIDIOUS '86
I see no pics...
Old 11-07-2012, 01:45 AM   #5
savatreatabvr
Sorry about that, my internet connection tends to drop data sometimes for some reason!
Old 11-07-2012, 01:49 AM   #6
savatreatabvr
And a smaller pic of one!
Old 11-07-2012, 01:59 AM   #7
INSIDIOUS '86
Well that will turn your dual plane more into a single plane. While it will work, it still will not be worth any power over the quadrajet that you have already. The cast iron intake is like forcing asthma on your engine. Don't matter what you put on top of it the throat (intake) still wont flow.
Old 11-07-2012, 05:00 AM   #8
85sierraclassic
85sierraclassic's Avatar
the last pic is the way you need to put it on make sure your throttle blades clear ok. but its universal so just flip it for what ever your doing. just make sure to hold your studs in from the bottom before its mounted or you get to take it back off and try again lol
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s
85sierraclassic is offline   Reply With Quote
Old 11-07-2012, 05:16 AM   #9
jjzepplin
jjzepplin's Avatar
And spin some nuts on them so they don't fall into your engine..
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
