Old 11-07-2012, 03:01 AM   #1
Andy4639
Old member
Andy4639's Avatar
Question Drilling rotor's
Has any one tried drilling a new set of rotor's?
Just wondering if it could be done and would it have any advantage over just new rotor's.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-07-2012, 05:36 AM   #2
skorpioskorpio
Re: Drilling rotor's
Drilled rotors are generally indexed between the vanes, so you better know exactly the path of the vanes before you commit. also the holes should be chamfered to reduce stress crack which will likely happen anyway. Your best bet is to do this on a CNC mill with lot and lots of cooling fluid so you don't disrupt the temper of the rotor.
Personally, while drilled rotors look cool, and they do, slotted rotors I feel accomplish the task better. They scuff the pad to make it grip more aggressively, they don't compromise the integrity of the rotor as much and don't reduce your surface area as much. Oh and they sound cool and let you brake later.
Once you get your brakes working really well, make sure your mirrors are good, having brakes better than the guy behind you isn't all upside.
skorpioskorpio is offline   Reply With Quote
Old 11-07-2012, 11:14 AM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Originally Posted by skorpioskorpio View Post
.....Once you get your brakes working really well, make sure your mirrors are good, having brakes better than the guy behind you isn't all upside.
Or, it may make it easier to get some money to finance some additional projects....just sayin'.
Member Nr. 2770
Old 11-07-2012, 12:34 PM   #4
GRX
GRX's Avatar
Drilled rotors are more susceptible to cracking. This can be reduced by rounding the edges of the holes. If you must have swiss cheese, shoot for rotors with cast holes instead.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 11-07-2012, 12:38 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Drilled rotors are over rated if you are going for looks.
Unless they are coated to prevent rust,... they end up looking like this.
Keith
Convert to disc brakes.
Old 11-07-2012, 12:57 PM   #6
truckster
truckster's Avatar
A picture truly is worth 1,000 words...
truckster is offline   Reply With Quote
Old 11-07-2012, 01:04 PM   #7
lolife99
lolife99's Avatar
Yep.
The outer most part of the rotor and the 1/4" strip next to the hub (where the contact area of the brake pad doesn't touch) will always rust.
But a smooth rotor will look cleaner because it cleans the rust every time you apply the brakes.
But those holes will always show the rust.
They suck.
I gave $135 each for mine,... thinking I was buying quality US made rotors.
But unless you pay a higher price for the coating they will look like this.
This is a picture from the internet,... but mine look just like this on my blazer.
Keith
Old 11-07-2012, 01:13 PM   #8
lolife99
lolife99's Avatar
Unless you are going with big brakes,... this looks better in my opinion.
Keith
Old 11-07-2012, 01:19 PM   #9
CC69Rat
CC69Rat's Avatar
Are mine gonna rust ? (are they coated?)
Anything I can do now to prevent it? Ex. Paint the rotors and let the pads wear off that it needs to?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 11-07-2012, 01:37 PM   #10
Ackattack
Ackattack's Avatar
I painted mine after they rusted initially. Eventually the paint will probably burn off and rust again.
Not really worth it IMO.
Ackattack is offline   Reply With Quote
Old 11-07-2012, 01:47 PM   #11
lolife99
lolife99's Avatar
Your's look zinc coated,... maybe.
Here's some pics from member nlped's thread.
These are a McGaughy's big brake kit.
Look at the before and after.
Large rotor,... but not that big of pad area.
Keith
Old 11-07-2012, 02:04 PM   #12
CC69Rat
CC69Rat's Avatar
Same as mine.. McGaughys.
Chad
Old 11-07-2012, 02:12 PM   #13
lolife99
lolife99's Avatar
I brought this old "rotor coatings" thread back to the top.
http://67-72chevytrucks.com/vboard/s...d.php?t=441756
Keith
Old 11-07-2012, 02:16 PM   #14
CC69Rat
CC69Rat's Avatar
Mine will rarely see water.. not really worried about it but I might still paint with some kind of preventative. Rustoleum or similar..
Chad
Old 11-07-2012, 02:19 PM   #15
lolife99
lolife99's Avatar
My blazer rotors will rust just setting in the garage from humidity.
I painted the hub and the edge,... but the two non-contact area of the rotor and the holes will rust.
Next time I will paint the entire rotor,... and they wil be smooth rotors.
Keith
Old 11-07-2012, 02:45 PM   #16
CC69Rat
CC69Rat's Avatar
I'm just going to quit using my brakes. Take em off.
Chad
Old 11-07-2012, 02:46 PM   #17
GRX
GRX's Avatar
In the past I have had success coating the rotors (inside and out) with high temp header paint. This was after a cycle in the shop hot tank to remove any oily deposits. Several years in my off road jeep and no rust, except on the pad surfaces after sitting.
edit: they were brand new rotors. Used ones with surface and internal rust present their own challenges.
Old 11-07-2012, 05:50 PM   #18
BarryB
BarryB's Avatar
Is this on a truck? I noticed the rack and pinion. I was wanting to do this to mine. Looking for ideas.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 11-07-2012, 06:58 PM   #19
Andy4639
Old member
Andy4639's Avatar
Question Re: Drilling rotor's
Well the price for coated rotor's drilled are out of my price range. I guess I'll just stay with regular rotor's. Mine seem to be fine was just curious.
Another ? though if I buy new rotors which ones are better for the rust coating? Is there a product that I can use myself?
Old 11-07-2012, 07:05 PM   #20
lolife99
lolife99's Avatar
Yes that's picture is on a member's truck that is equipped with a Porterbuilt Dropmember.
They use a 79-93 mustang rack for steering.
Look here:
http://www.porterbuiltfabrication.co...p?63-La-Perica
And here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354512
Keith
Old 11-07-2012, 10:32 PM   #21
BigCountryx
BigCountryx's Avatar
Check out lowlife's pic. See the tiny cracks that appear starting at the holes? Mine are doing the same. I'll never buy another set of drilled rotors.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped
1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant
BigCountryx is offline   Reply With Quote
Old 11-07-2012, 10:39 PM   #22
lpaine
lpaine's Avatar
I've seen slotted rotors that look like they would offer some advantages over drilled (which seem overrated on a street truck) don't remember where I exactly saw them though; easy search I would think to find some....
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 11-07-2012, 11:03 PM   #23
69GWC
I have crossed drilled and slotted rotors on the front of my 06, I did this not for looks but to help keep heat down as for some reason the stock rotors kept warping on me around every 10/15,000 miles or so. With these on there I have yet to have a issue even pulling a trailer daily.
69GWC is offline   Reply With Quote
