Old 11-07-2012, 12:21 PM   #1
scoutcamper
Question Locking Fuel Cap
Hey all,
I have a "new(previouly ignored)" issue on my 71 build. the locking fuel cap that i purhased from chevyduty (will link below) Leaks. When i go around a corner gas pours out of the fuel cap. We found a "non vented fuel cap" from a 72' parts truck that we picked up awhile back, and that does the same thing. Any suggestions to not leak fuel every time you make a turn?
the cap i purchased is http://www.classicparts.com/1938-71-.../#.UJqKBYaz6o8
scoutcamper is offline   Reply With Quote
Old 11-07-2012, 12:44 PM   #2
Mister-B
Re: Locking Fuel Cap
Originally Posted by scoutcamper View Post
Hey all,
Are you topping off too much gas when you fill up? LMC sells a locking gas cap. Maybe you could try that as well.
Mister-B is offline   Reply With Quote
Old 11-07-2012, 01:22 PM   #3
scoutcamper
I have to leave the tank 1/4 low when i fuel it up or it dumps fuel, so im not putting to much gas in it...
Old 11-07-2012, 02:19 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Got my locking cap from NAPA, p/n 703-1113, no leaks. It's actually my second cap from them, the first lasted many years before the seal finally rotted and gas started sloshing out on right-hand corners.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-07-2012, 03:49 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Member Nr. 2770
Old 11-07-2012, 05:24 PM   #6
scoutcamper
Guys-this looks just like the cap i took off of the 72 donor truck, it did not in fact seat itself correctly on the 71' . I will go to napa today or tommorow and compare the 2 caps....
Old 11-07-2012, 06:13 PM   #7
1972SUPERSB
1972SUPERSB's Avatar
I think I tried this gas Cap. Does it move up and down once you turn and tighten it? Seems like the one i bought was a little loose once you turn and tighten It. I'm having a hard time finding a cap that fits correctly. Locking or non locking.
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 11-07-2012, 06:48 PM   #8
original-71
///Relaxed Atmosphere
original-71's Avatar
very nice looking cap too bad it leaks
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 11-07-2012, 06:56 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
It doesn't turn at all, you just press it straight down onto the filler neck and two tangs lock it in place. Internal spring(s) keep outward pressure on it to maintain proper seal. You can press it downward against the spring(s) and it will push back up as you take your hand off it.
Gas Cap - Locking
Part Number: BK 7031113
Product Line: Balkamp
IMPORTANT INFO: Boxed Product
- Mike -
RIP El Jay
Old 11-07-2012, 07:06 PM   #10
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Gas Cap - Locking
The first purchase I made after I bought my truck in 2001 was one of these gas caps and it stil on the truck doing its job. My reason for buying the locking cap was I didn't want someone to steal my gas or sweeten the gas with a little sugar or some other foreign material.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 11-07-2012, 07:44 PM   #11
Billett
Billett's Avatar
Paint's faded on mine, but I'm pretty sure I have that cap as well on my 68. I haven't noticed any leaks yet.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 11-07-2012, 08:13 PM   #12
99-LS1-SS
99-LS1-SS's Avatar
I WILL be getting one of those locking caps. Thank you for the information.
My 1972 2WD Blazer build
1984 K10 beater truck
99-LS1-SS is offline   Reply With Quote
Old 11-07-2012, 10:27 PM   #13
dlh760
dlh760's Avatar
I tried that exact locking gas cap on my truck because original leaked on right turns. That cap leaked worse than original so I put a seal about 1/4" thick over the gas cap seal and it doesn't leak anymore.
68 Chevy c10 longbed 307 with 305 H.O. heads,edelbrock performer intake,edelbrock performer plus cam,hei,Holley 650 double pumper and th400. Daily driver. It hauls butt,it hauls my butt where I need to go
dlh760 is offline   Reply With Quote
Old 11-07-2012, 10:53 PM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Interesting, glad you could fix it! What did you use for the thicker seal?
- Mike -
RIP El Jay
Old 11-07-2012, 11:02 PM   #15
dlh760
dlh760's Avatar
I work in a hydraulic shop and it is just a basic rod protector seal we have that was the right size to fit the cap. It takes some effort to get the cap on now but it doesn't leak
Old 11-07-2012, 11:02 PM   #16
Sicklajoie
The Niner
Sicklajoie's Avatar
The only thing I hate about that cap is that it says Made in May-he-ko.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 11-07-2012, 11:40 PM   #17
Square_78
Square_78's Avatar
I got a locking cap locally from KMS. It's prob the same one as LMC would have. It's shiney chrome and rounded and looks good. I have the one from napa on my 78 and it's ugly. Neither of them leak any fuel. The one from KMS seems a little weak on the sealing department, but so far it's not leaking any gas
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 11-08-2012, 08:04 AM   #18
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I have the same situation on my 71. Same cap on both my 69 & 71 but had leaks only on that truck. For now, I found a plastic cap of some type that fit over the filler neck and the gas cap goes over it. (acts like an extension of the rubber gasket) I tried to glue it in place but that horrible ethenol won't allow that. It stopped the leak for now until I can figure out a better plan.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
